How can i have space in a dispvm
I have a qube called usb-dvm just to write files and reformat usb drives i also use this qube to install iso’s and flash them on the usb. The problem is i cant change the space in my dispvm. When i got to change vm’s storage it displays this error message " Logical volume vm-usb-dvm-private-snap not found in volume group qubes_dom0". Any help is appreciated
What version of Qubes are you using?
I’m assuming that usb-dvm is a normal template based qube used as a
disposable template. Right?
How are you trying to change the size of the private volume?
I am running 4.2 not the latest.
Yes i just took the debian disp template and made a qube named usb-dvm. I cant change the storage, i tried to change it from the ui settings and got returned that message.
