I’ve created a disposable template that uses a specific network qube. However, every disposable app I generate from this template seems to be connected to a different network. How can I adjust the network settings for the disposables created from this template?
How do I configure the network settings for disposables created from a specific template?
I need to air-gap a template but provide network access to its disposables, and I have a disposable template that’s not using the correct network; how do I fix this?
Then why do my disposables use a different net than what I have its parent set to?
I have double triple checked, and the template has the right net qube set. But every one made from it uses a different one.
I would quadruple check this,
Or you could provide sufficient information for others to be able to
replicate this - you could start with the Qubes version. the basis for
the disposable template, the netvm for the disposable template, and the
netvm used by (every?) disposable.
Quadruple checked it.
Restarted my computer to make sure everything was updated, checked with “qvm-prefs” in Dom0, checked in the GUI, and launched the template itself. They all use/report the expected Netvm.
I launch a disposable from it, check from within the VM itself, Dom0, and the GUI. All show the unexpected Netvm.
I have no named-disposables or similarly named Qubes on my computer I could possibly be confusing it with.
What do you do to launch a disposable from template?
You could try executing qvm-run -q -a --service --dispvm=<your_template> -- qubes.StartApp+<app> to start a disposable from dom0 and then checking whether networks are truly different.
Another option would be starting from scratch. Try creating new disposable template and running disposable based off of it:
qvm-create --class AppVM --property template_for_dispvms=True --label red testmydvm
qvm-run -q -a --service --dispvm=testmydvm -- qubes.StartApp+qubes-run-terminal
I got things working again by starting from the beginning. If there might be a security issue, I can certainly go back and look at what I did initially. I believe I can figure out how to recreate the problem. In fact, I’ve run into it several times while trying to do the same thing.
It would be extremely helpful if you could say what you did
initially, and what you did this time. Provide sufficient
detail for the issue to be replicated, including the basis for the
disposable template, the netvm you tried to use and the netvm that was
used, also the global parameter for default netvm.
