Hotkey for screen lock?
Hello there,
I would like to have a hotkey, or key combination, to lock my screen. I did look through the docs but possibly I’m looking for the wrong keywords as I was unsuccessful.
Someone? Cheers!
Try this:
CTRL+ALT+L
Bishop
Thank you!
Any way to change this hotkey, set up others?
Away from my Qubes system and answering from my phone, but try looking at the Keyboard settings in dom0 (it’s listed in the application menu). There should be a shortcut section where you can customize many things.
For what it’s worth, I think this is pretty much xfce default behaviour and nothing too Qubes-specific.
This is an Xfce4 thing, nothing Qubes-specific.
Applications Menu -> System Tools -> Keyboard -> Application Shortcuts
Create/modify whichever shortcuts you like for the command xflock4.
