I am trying to figure out if it is possible with Qubes to host full remote VMs.
For instance, if I have Qubes installed on my main computer, and want to connect to a full Ubuntu desktop VM hosted on the qubes machine from a zero client or a laptop with client software.
Is this possible with the security stuff, and
If so, what is the best way to approach? Running the VM hosting hypervisor in a Qube or doing it through the built-in Xen architecture?
To connect to a qube you’ll have to go through dom0 first. That weakens security in so many ways, but below is an article on how to do this very securely,
It isnt altogether clear to me what it is you are asking. I think you
are asking if you can have a qube running Ubuntu with the full desktop
installed, and then connect to the Qubes machine so as to load up the
Ubuntu desktop.
It isnt clear to me whether you want the Ubuntu qube to be able to work
with the rest of the qubes on that machine.
You can do this, without compromising dom0 in a few ways:
Run an admin qube that is remotely accessible, has limited access to
other qubes, and from which you can control the Ubuntu qube. Take a
look at this post that introduced the concept
Run a separate sys-gui-vnc which is remotely accessible, and have the
Ubuntu qube use that as guivm. Redirecting…
Run vncserver in the Ubuntu qube. Set up an ssh tunnel from sys-net to the
Ubuntu qube, either by forwarding down the Qubes network, or using
TCPConnect. Once the tunnel is connected you can use a vncviewer on your
local machine to view the desktop of the remote Ubuntu.
Undoubtedly there are other possibilities. I would favor 3 as simplest
to set up. Whatever you choose, you should set restrictive policies on
the Ubuntu qube so that you do not inadvertently expose other qubes from
it.
Yes. You can do this with virt-manager over ssh. Audio and resizing work, but I haven’t gotten remote 3d acceleration working. Make sure your remote user is in the libvrit-users group.
