Highlighting @neowutran's technical doc about Qubes
Found deep in this thread:
And then updated most recently last month:
It’s a comprehensive 62 page document with a lot of code and commentary, the custom qubes @neowutran has created for his home server.
Here’s the table of contents, so you can see what it covers:
It looks like a pretty helpful reference to me, so I wanted to highlight it.
FYI, you will get a certificate warning when you browse to the doc. The reason for which is explained in section 2.1. :slight_smile:
Thanks for highlighting this, @neowutran has written some incredible things and I keep being surprised at the gems being unearthed :slight_smile:
(thanks ! :slight_smile: And if you have improvement ideas, don’t hesitate to say )
