Help with salt error on unman splitssh
Tried to create unmans split-ssh setup via the salt scripts. I only modfied the template names.
I can’t figure why the configuration of the qubes-ssh-agent.configure_template fails.
debian-13-minimal-ssh-agent: ERROR (exception list index out of range)
Could somebody with more salt experience pls help out?
It would be extremely helpful if you could say:
What version of Qubes you are running.
What template is used by default-mgmt-dvm.
What command you used to run the state.
Can you now run;
qubesctl --skip-dom0 --targets=TEMPLATE --show-output state.apply qubes-ssh-agent.configure_template
replacing TEMPLATE with the name of the template, and post the output.
In general it is always a good first step to run a failing command with
--show-output.
Sry. 4.3, I tried fedora-42-xfce and debian-13-minimal with bash and fish for the default-dvm
I ran sudo qubesctl --skip-dom0 --targets=template-ssh-agent state.apply qubes-ssh-agent.configure_template
I cloned the repo, changed the debian template to 13 then moved the entire dir to /srv/salt.
–show-output does not show anything extra
Sorry was not thinking straight. For some reason I thought changing the template for the default-dvm would also change it for the mgmt.
It’s a minimal template error, with xfce it works. Sorry again
