Hi, long story short. I have a t480 that i recently libreboot it, everything works perfect except the jack. The solution to the problem is use pulseaudio but qubes by default use pipewire and i can´t find a way to change it to pulse audio. I tried using in dom0: sudo qubes-dom0-update --switch-audio-server-to=pulseaudio but it doesn’t seem to work.
Well, that is not a lot of info, is it?
did you log out of dom0, or did you reboot, as this post suggests?
This is the full output:
[user@dom0 ~]$ sudo qubes-dom0-update --switch-audio-server-to=pulseaudio
Using sys-firewall as UpdateVM for Dom0
Downloading updates. This may take a while...
Updating and loading repositories:
Fedora 37 - x86_64 100% | 34.0 MiB.0 B
Qubes Host Repository (updates) 100% | 461.9 KiB
Fedora 37 - x86_64 - Updates 100% | 11.9 MiB
_[?25hRepositories loaded.
Nothing to do.
No packages downloaded
Qubes OS Repository for Dom0 1.2 MB/s | 3.0 kB 00:00
Switching from PipeWire to Pulseaudio
Performing swap. This may take a while...
Fedora 37 - x86_64 - Updates 100% | 5.9 KiB.0 B
Fedora 37 - x86_64 100% | 6.0 KiB
Qubes Host Repository (updates) 100% | 2.7 KiB
_[1mPackage _[0m _[1mArch _[0m _[1mVersion _[0m _[1mRepository _[0m _[1m Size_[0m
Removing:
_[31m pipewire _[0m x86_64 0.3.84-1.fc37 <unknown> 344.6 KiB
Removing dependent packages:
_[31m pipewire-pulseaudio _[0m x86_64 0.3.84-1.fc37 <unknown> 412.2 KiB
_[31m pipewire-qubes _[0m x86_64 4.2.20-1.fc37 <unknown> 71.8 KiB
Installing:
_[32m pulseaudio _[0m x86_64 16.1-4.fc37 updates 3.9 MiB
Transaction Summary:
Installing: 1 package
Removing: 3 packages
Total size of inbound packages is 1 MiB. Need to download 1 MiB.
After this operation, 3 MiB extra will be used (install 4 MiB, remove 829 KiB).
_[?25l[1/1] pulseaudio-0:16.1-4.fc37.x86_64 0% | 0.0 B
[1/1] pulseaudio-0:16.1-4.fc37.x86_64 0% | 7.1 KiB
[1/1] pulseaudio-0:16.1-4.fc37.x86_64 1% | 15.1 KiB
[1/1] pulseaudio-0:16.1-4.fc37.x86_64 4% | 47.1 KiB
[1/1] pulseaudio-0:16.1-4.fc37.x86_64 9% | 95.1 KiB
[1/1] pulseaudio-0:16.1-4.fc37.x86_64 15% | 159.1 KiB
[1/1] pulseaudio-0:16.1-4.fc37.x86_64 27% | 287.1 KiB
[1/1] pulseaudio-0:16.1-4.fc37.x86_64 40% | 423.1 KiB
[1/1] pulseaudio-0:16.1-4.fc37.x86_64 53% | 559.1 KiB
[1/1] pulseaudio-0:16.1-4.fc37.x86_64 68% | 711.1 KiB
[1/1] pulseaudio-0:16.1-4.fc37.x86_64 82% | 855.1 KiB
[1/1] pulseaudio-0:16.1-4.fc37.x86_64 99% | 1.0 MiB
[1/1] pulseaudio-0:16.1-4.fc37.x86_64 100% | 1.0 MiB
[1/1] Total 100% | 1.0 MiB
Running transaction
_[?25lTransaction failed: Rpm transaction failed.
_[?25h_[?25h[user@dom0 ~]$
