Hello, I am trying to install either Arch Linux or Ubuntu in a HVM. Everything works except for networking? I assigned the NetVM to sys-firewall. This exact same setup works fine for my Windows.
-Ryan
-Ryan
And did you set the network settings in Ubuntu (and Arch) the same way, you have it outside?
sys-firewall IP = Ubuntu-network settings for Gateway
UbuntuQube-IP = Ubuntu-network settings for own IP
it actually should work with the auto-DHCP settings inside, but maybe it’s worth a try to set the settings manually
You will probably have to set the network details manually.
Get these details from the Settings for the qube, under “Networking”.
Set them in the HVM - but use a netmask of 255.0.0.0.
