Help with dnscrypt-proxy
I installed dnscrypt-proxy in the fedora 42 template. Do I need to change dns in the template so that appvms retain the changes? Or do I need to run dnscrypt-proxy in the appvms? If latter, please help me how to do it. I understand that I need to edit sudo nano /rw/config/rc.local
If I need to change dns in template, do I just need to disable systemd-resolver and add the address 127.0.2.1 to resolv.conf?
I thought I should add this to sudo nano /rw/config/rc.local
systemctl stop systemd-resolved
systemctl disable systemd-resolved
echo "nameserver 127.0.2.1"  | tee /etc/resolv.conf
systemctl restart dnscrypt-proxy
but it didn’t work
Look at this tutorial of @qubist :
And this one to configure sys-dns and sys-wall to change nftable instead of iptable:
It’s what i use :slight_smile:
Hi, Tezeria! :slightly_smiling_face:
Will it work for fedora 42? What fedora version do you have now?
I’m still on fedora 41 so I can’t tell you.
Okay. Thank you :heart: I will try it tomorrow on fedora 42 and write result.
@qubist are you using fedora 42 for dnscrypt-proxy right now or fedora 41 too?
I have stopped using Fedora templates a fairly long time ago. I use only Debian now. I am not using DNSCrypt currently. I have been preparing a guide for Debian (using a better approach) but unfortunately I am overwhelmed with all kinds of problems, so I am still not ready with it. I hope you have the patience.
@Tezeria - glad to see you around!
For sure :wink:
Do you use something else?
Of course! Your guides and tools are really awesome! Thank you for your work for the Qubes community!
So it work with fedora-minimal-42 ?
I haven’t done it yet. I was busy setting up the second sys-vpn, then I tested dom0-live in btrfs. Now I’m waiting for qubist post about dnscrypt-proxy. For now, I’ve only added dns-over-tls to some appVms
/rw/config/rc.local
systemd-resolve --set-dns=9.9.9.9 --set-dnsovertls=yes --interface=eth0
ln -sf /run/systemd/resolve/stub-resolv.conf /etc/resolv.conf
systemctl restart systemd-resolved
https://dns.watch/ for the small amount of clearnet. However, I dare to say their “Optimized for maximum speed” boasting is far from true, at least for me :slight_smile:
Ok, so i’ll stay with dsncrypt! lol :slight_smile:
