Help needed Qubes 4.2.4 installer freezes on Lenovo X Carbon G
So I tried several Times over the last weeks to install Qubes 4.2.4 on my Lenovo X Carbon Gen 7 which has 16 GO Ram.
Basically I tried to do so on an external SSD drive. It failed despite trying different USB key and tweak that I found working for some people ( adding some lines in Grub). Did not work. I finally bought 2 new USB key and it worked to some extent. Problem is Qubes does not have access to internet ( WiFi). When I plug an ethernet cable it freezes. Since this should be related to the sys USB or something like that I decided to partition my computer hard drive. Now it again freezes at any moment after the installer appears. I m starting to drive crazy. I tried to add the cpufreq=xen:hwp=off command on Grub does not do anything. I tried chatGPT . Its advices did not work.
Could anyone help ? Because I really want to use Qubes but now I m on the verge of quitting.
