Is there some certainty that Qubes will work with 14700 i7? Are there some workarounds maybe I can apply if it won’t work? I really don’t want to buy some old CPU…
Also, how do i check if the motherboard will work? I can choose from many at the moment, but this one looks nice
Will I be able to use RTX 4060 with sys-gui and attach 3 monitors? Maybe I didn’t understand what’s sys-gui…
Ah! Thanks for that… I accept the fact I won’t be able to get rid of intel ME, but the Coreboot is a good addition to security and privacy.
There are differences between them… some noticeable… on the P version there’s no WiFi 7…
