Have been beating my empty head against the wall for a couple of weeks attempting to install LibreOffice.
Have downloaded the LibreOffice file from LibreOffice site. Moved over to the Work/Template file directory. But can not get it to run. Have searched the web for help and no joy. Lots of stuff, but nothing for Qubes/LibreOffice saying:
Step One;
Step Two:
Step Three:
If someone could possible help a feeble brain newbie to Qubes it would be greatly appreciated.
Once I get LibreOffice installed I will be happy to document the process and post on this site where appropriate.
Iâve never tried this, but the tooltip for that button states that itâs chiefly for debugging purposes and suggests using a regular terminal instead. I usually execute this sort of command in dom0:
Out of curiosity, how do you even use it? When I selected a qube and clicked that button, it started a disposable, then opened (what appears to be) an xterm window with the title sh in that disposable, but I donât have a command prompt or anything. I can type in the window, but it doesnât do anything.
That doesnât always work, sometimes you just get the black screen.
Another issue I have with the console option is that the dvm can hang, and when that happens, you canât restart the qube without getting an error that a volatile image with the same name already exists.
I have been successful with installing LibreOffice. I want to thank everyone for their time and responses.
One issue I found was not all the instructions work. My end result was to reinstall Qubes fresh, something I have become very adept at, and do the following:
Download LibreOffice install from LibreOffice site to the untrusted cube.
Copy the Work cube to create a new cube
Using the File Manager, copy the LibreOffice download to the new cube template directory
Unzip the zipped install files.
5 Run âsudo dnf install LibreOfficeâ. Fedora cube. This is something I tried previously by would not install.
Shut down and restarted Qubes.
Using the App Manager selected and added LibreOffice to the new cube.
Shut down and restart the new cube. All is golden in cyber land, LibreOffice showed up.
