Help! Cannot Start Particular AppVM, Log Parsing Request
There is one AppVM I use particularly often, containing several GB of personal data, Thunderbird / email, Emacs notes, etc. Just today, I have been unable to restart this AppVM. It continually fails to start, and after 60 seconds, dom0 tells me to check the logs in /var/log/xen/console/guest-private.log (private is the name of the AppVM).
Logs are below. I see some “ERROR” messages (e.g., ACPI Error: No handler or method for GPE 00, disabling event (20240827/evgpe-839)), but am not sure which are actually preventing the AppVM from starting, nor how to resolve.
Qubes R4.2. Template is based on Fedora-41, which is EOL, but I have several other AppVMs using the exact same template and are working just fine.
Here are the full logs
[2026-03-11 12:17:04] Logfile Opened
[2026-03-11 12:17:05] [ 0.000000] Linux version 6.12.64-1.qubes.fc37.x86_64 (mockbuild@51a32a9408d447b09b468d459920d037) (gcc (GCC) 12.3.1 20230508 (Red Hat 12.3.1-1), GNU ld version 2.38-27.fc37) #1 SMP PREEMPT_DYNAMIC Sat Jan 10 20:39:04 GMT 2026
[2026-03-11 12:17:05] [ 0.000000] Command line: root=/dev/mapper/dmroot ro nomodeset console=hvc0 rd_NO_PLYMOUTH rd.plymouth.enable=0 plymouth.enable=0 clocksource=tsc xen_scrub_pages=0 swiotlb=2048 selinux=1 security=selinux
[2026-03-11 12:17:05] [ 0.000000] BIOS-provided physical RAM map:
[2026-03-11 12:17:05] [ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
[2026-03-11 12:17:05] [ 0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[2026-03-11 12:17:05] [ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000fbffffff] usable
[2026-03-11 12:17:05] [ 0.000000] BIOS-e820: [mem 0x00000000fc000000-0x00000000fc00803f] ACPI data
[2026-03-11 12:17:05] [ 0.000000] BIOS-e820: [mem 0x00000000feff8000-0x00000000feffffff] reserved
[2026-03-11 12:17:05] [ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x00000002f1ffffff] usable
[2026-03-11 12:17:05] [ 0.000000] NX (Execute Disable) protection: active
[2026-03-11 12:17:05] [ 0.000000] APIC: Static calls initialized
[2026-03-11 12:17:05] [ 0.000000] DMI not present or invalid.
[2026-03-11 12:17:05] [ 0.000000] Hypervisor detected: Xen HVM
[2026-03-11 12:17:05] [ 0.000000] Xen version 4.17.
[2026-03-11 12:17:05] [ 0.080120] tsc: Fast TSC calibration failed
[2026-03-11 12:17:05] [ 0.080125] tsc: Detected 2495.994 MHz processor
[2026-03-11 12:17:05] [ 0.080149] last_pfn = 0x2f2000 max_arch_pfn = 0x400000000
[2026-03-11 12:17:05] [ 0.080173] MTRR map: 0 entries (0 fixed + 0 variable; max 16), built from 8 variable MTRRs
[2026-03-11 12:17:05] [ 0.080176] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[2026-03-11 12:17:05] [ 0.080209] last_pfn = 0xfc008 max_arch_pfn = 0x400000000
[2026-03-11 12:17:05] [ 0.091303] Using GB pages for direct mapping
[2026-03-11 12:17:05] [ 0.091512] RAMDISK: [mem 0x03c01000-0x04fa0fff]
[2026-03-11 12:17:05] [ 0.091596] ACPI: Early table checksum verification disabled
[2026-03-11 12:17:05] [ 0.091600] ACPI: RSDP 0x00000000FC008000 000024 (v02 Xen )
[2026-03-11 12:17:05] [ 0.091605] ACPI: XSDT 0x00000000FC007F70 000034 (v01 Xen HVM 00000000 HVML 00000000)
[2026-03-11 12:17:05] [ 0.091611] ACPI: FACP 0x00000000FC007D60 00010C (v05 Xen HVM 00000000 HVML 00000000)
[2026-03-11 12:17:05] [ 0.091617] ACPI: DSDT 0x00000000FC001040 006C9B (v05 Xen HVM 00000000 INTL 20220331)
[2026-03-11 12:17:05] [ 0.091620] ACPI: FACS 0x00000000FC001000 000040
[2026-03-11 12:17:05] [ 0.091623] ACPI: FACS 0x00000000FC001000 000040
[2026-03-11 12:17:05] [ 0.091626] ACPI: APIC 0x00000000FC007E70 00004C (v02 Xen HVM 00000000 HVML 00000000)
[2026-03-11 12:17:05] [ 0.091628] ACPI: Reserving FACP table memory at [mem 0xfc007d60-0xfc007e6b]
[2026-03-11 12:17:05] [ 0.091630] ACPI: Reserving DSDT table memory at [mem 0xfc001040-0xfc007cda]
[2026-03-11 12:17:05] [ 0.091630] ACPI: Reserving FACS table memory at [mem 0xfc001000-0xfc00103f]
[2026-03-11 12:17:05] [ 0.091631] ACPI: Reserving FACS table memory at [mem 0xfc001000-0xfc00103f]
[2026-03-11 12:17:05] [ 0.091632] ACPI: Reserving APIC table memory at [mem 0xfc007e70-0xfc007ebb]
[2026-03-11 12:17:05] [ 0.091795] No NUMA configuration found
[2026-03-11 12:17:05] [ 0.091798] Faking a node at [mem 0x0000000000000000-0x00000002f1ffffff]
[2026-03-11 12:17:05] [ 0.091806] NODE_DATA(0) allocated [mem 0x2f1fd42c0-0x2f1ffefff]
[2026-03-11 12:17:05] [ 0.091964] Zone ranges:
[2026-03-11 12:17:05] [ 0.091965] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[2026-03-11 12:17:05] [ 0.091966] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[2026-03-11 12:17:05] [ 0.091967] Normal [mem 0x0000000100000000-0x00000002f1ffffff]
[2026-03-11 12:17:05] [ 0.091968] Device empty
[2026-03-11 12:17:05] [ 0.091969] Movable zone start for each node
[2026-03-11 12:17:05] [ 0.091970] Early memory node ranges
[2026-03-11 12:17:05] [ 0.091971] node 0: [mem 0x0000000000001000-0x000000000009ffff]
[2026-03-11 12:17:05] [ 0.091972] node 0: [mem 0x0000000000100000-0x00000000fbffffff]
[2026-03-11 12:17:05] [ 0.091973] node 0: [mem 0x0000000100000000-0x00000002f1ffffff]
[2026-03-11 12:17:05] [ 0.091974] Initmem setup node 0 [mem 0x0000000000001000-0x00000002f1ffffff]
[2026-03-11 12:17:05] [ 0.091979] On node 0, zone DMA: 1 pages in unavailable ranges
[2026-03-11 12:17:05] [ 0.091994] On node 0, zone DMA: 96 pages in unavailable ranges
[2026-03-11 12:17:05] [ 0.105552] On node 0, zone Normal: 16384 pages in unavailable ranges
[2026-03-11 12:17:05] [ 0.105750] On node 0, zone Normal: 24576 pages in unavailable ranges
[2026-03-11 12:17:05] [ 0.105826] ACPI: No IOAPIC entries present
[2026-03-11 12:17:05] [ 0.105828] ACPI: Using ACPI for processor (LAPIC) configuration information
[2026-03-11 12:17:05] [ 0.105830] TSC deadline timer available
[2026-03-11 12:17:05] [ 0.105833] CPU topo: Max. logical packages: 1
[2026-03-11 12:17:05] [ 0.105835] CPU topo: Max. logical dies: 1
[2026-03-11 12:17:05] [ 0.105835] CPU topo: Max. dies per package: 1
[2026-03-11 12:17:05] [ 0.105838] CPU topo: Max. threads per core: 1
[2026-03-11 12:17:05] [ 0.105839] CPU topo: Num. cores per package: 4
[2026-03-11 12:17:05] [ 0.105839] CPU topo: Num. threads per package: 4
[2026-03-11 12:17:05] [ 0.105840] CPU topo: Allowing 4 present CPUs plus 0 hotplug CPUs
[2026-03-11 12:17:05] [ 0.105848] [mem 0xfc008040-0xfeff7fff] available for PCI devices
[2026-03-11 12:17:05] [ 0.105854] Booting kernel on Xen PVH
[2026-03-11 12:17:05] [ 0.105855] Xen version: 4.17.6
[2026-03-11 12:17:05] [ 0.105858] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns
[2026-03-11 12:17:05] [ 0.111913] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:4 nr_cpu_ids:4 nr_node_ids:1
[2026-03-11 12:17:05] [ 0.112089] percpu: Embedded 88 pages/cpu s237568 r8192 d114688 u524288
[2026-03-11 12:17:05] [ 0.112116] PV qspinlock hash table entries: 256 (order: 0, 4096 bytes, linear)
[2026-03-11 12:17:05] [ 0.112118] Kernel command line: root=/dev/mapper/dmroot ro nomodeset console=hvc0 rd_NO_PLYMOUTH rd.plymouth.enable=0 plymouth.enable=0 clocksource=tsc xen_scrub_pages=0 swiotlb=2048 selinux=1 security=selinux
[2026-03-11 12:17:05] [ 0.112145] Booted with the nomodeset parameter. Only the system framebuffer will be available
[2026-03-11 12:17:05] [ 0.112223] Unknown kernel command line parameters “rd_NO_PLYMOUTH”, will be passed to user space.
[2026-03-11 12:17:05] [ 0.112234] random: crng init done
[2026-03-11 12:17:05] [ 0.113334] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[2026-03-11 12:17:05] [ 0.113908] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[2026-03-11 12:17:05] [ 0.113980] Fallback order for Node 0: 0
[2026-03-11 12:17:05] [ 0.113983] Built 1 zonelists, mobility grouping on. Total pages: 3071903
[2026-03-11 12:17:05] [ 0.113984] Policy zone: Normal
[2026-03-11 12:17:05] [ 0.114158] mem auto-init: stack:all(zero), heap alloc:on, heap free:on
[2026-03-11 12:17:05] [ 0.114159] mem auto-init: clearing system memory may take some time…
[2026-03-11 12:17:05] [ 0.114166] software IO TLB: area num 4.
[2026-03-11 12:17:05] [ 0.962649] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[2026-03-11 12:17:05] [ 0.962681] ftrace: allocating 59511 entries in 233 pages
[2026-03-11 12:17:05] [ 0.968994] ftrace: allocated 233 pages with 5 groups
[2026-03-11 12:17:05] [ 0.969063] Dynamic Preempt: full
[2026-03-11 12:17:05] [ 0.969101] rcu: Preemptible hierarchical RCU implementation.
[2026-03-11 12:17:05] [ 0.969102] rcu: RCU event tracing is enabled.
[2026-03-11 12:17:05] [ 0.969102] rcu: RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=4.
[2026-03-11 12:17:05] [ 0.969104] Trampoline variant of Tasks RCU enabled.
[2026-03-11 12:17:05] [ 0.969105] Rude variant of Tasks RCU enabled.
[2026-03-11 12:17:05] [ 0.969105] Tracing variant of Tasks RCU enabled.
[2026-03-11 12:17:05] [ 0.969106] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
[2026-03-11 12:17:05] [ 0.969106] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[2026-03-11 12:17:05] [ 0.969113] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[2026-03-11 12:17:05] [ 0.969115] RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[2026-03-11 12:17:05] [ 0.969116] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[2026-03-11 12:17:05] [ 0.971971] NR_IRQS: 524544, nr_irqs: 80, preallocated irqs: 16
[2026-03-11 12:17:05] [ 0.972019] xen:events: Using FIFO-based ABI
[2026-03-11 12:17:05] [ 0.972030] xen:events: Xen HVM callback vector for event delivery is enabled
[2026-03-11 12:17:05] [ 0.972197] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[2026-03-11 12:17:05] [ 0.972311] kfence: initialized - using 2097152 bytes for 255 objects at 0x(ptrval)-0x(ptrval)
[2026-03-11 12:17:05] [ 0.972346] Console: colour dummy device 80x25
[2026-03-11 12:17:05] [ 0.972360] printk: legacy console [hvc0] enabled
[2026-03-11 12:17:05] [ 0.973460] ACPI: Core revision 20240827
[2026-03-11 12:17:05] [ 0.973514] ACPI: setting ELCR to 0200 (from ffff)
[2026-03-11 12:17:05] [ 0.973550] APIC: Switch to symmetric I/O mode setup
[2026-03-11 12:17:05] [ 0.973568] x2apic enabled
[2026-03-11 12:17:05] [ 0.973613] APIC: Switched APIC routing to: physical x2apic
[2026-03-11 12:17:05] [ 0.973634] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x23fa717cb36, max_idle_ns: 440795237972 ns
[2026-03-11 12:17:05] [ 0.973651] Calibrating delay loop (skipped), value calculated using timer frequency… 4991.98 BogoMIPS (lpj=2495994)
[2026-03-11 12:17:05] [ 0.973732] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[2026-03-11 12:17:05] [ 0.973768] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
[2026-03-11 12:17:05] [ 0.973776] Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
[2026-03-11 12:17:05] [ 0.973789] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[2026-03-11 12:17:05] [ 0.973803] Spectre V2 : Mitigation: Enhanced / Automatic IBRS
[2026-03-11 12:17:05] [ 0.973811] Spectre V2 : Spectre v2 / PBRSB-eIBRS: Retire a single CALL on VMEXIT
[2026-03-11 12:17:05] [ 0.973823] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[2026-03-11 12:17:05] [ 0.973835] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[2026-03-11 12:17:05] [ 0.973847] Register File Data Sampling: Mitigation: Clear Register File
[2026-03-11 12:17:05] [ 0.973871] x86/fpu: Supporting XSAVE feature 0x001: ‘x87 floating point registers’
[2026-03-11 12:17:05] [ 0.973882] x86/fpu: Supporting XSAVE feature 0x002: ‘SSE registers’
[2026-03-11 12:17:05] [ 0.973891] x86/fpu: Supporting XSAVE feature 0x004: ‘AVX registers’
[2026-03-11 12:17:05] [ 0.973899] x86/fpu: Supporting XSAVE feature 0x200: ‘Protection Keys User registers’
[2026-03-11 12:17:05] [ 0.973910] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[2026-03-11 12:17:05] [ 0.973919] x86/fpu: xstate_offset[9]: 832, xstate_sizes[9]: 8
[2026-03-11 12:17:05] [ 0.973928] x86/fpu: Enabled xstate features 0x207, context size is 840 bytes, using ‘compacted’ format.
[2026-03-11 12:17:05] [ 0.974649] Freeing SMP alternatives memory: 52K
[2026-03-11 12:17:05] [ 0.974649] pid_max: default: 32768 minimum: 301
[2026-03-11 12:17:05] [ 0.974649] LSM: initializing lsm=lockdown,capability,yama,selinux,ima,evm
[2026-03-11 12:17:05] [ 0.974649] Yama: becoming mindful.
[2026-03-11 12:17:05] [ 0.974649] SELinux: Initializing.
[2026-03-11 12:17:05] [ 0.974649] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[2026-03-11 12:17:05] [ 0.974649] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[2026-03-11 12:17:05] [ 0.974649] clocksource: xen: mask: 0xffffffffffffffff max_cycles: 0x1cd42e4dffb, max_idle_ns: 881590591483 ns
[2026-03-11 12:17:05] [ 0.974649] installing Xen timer for CPU 0
[2026-03-11 12:17:05] [ 0.974649] smpboot: CPU0: 12th Gen Intel(R) Core™ i7-1260P (family: 0x6, model: 0x9a, stepping: 0x3)
[2026-03-11 12:17:05] [ 0.974649] cpu 0 spinlock event irq 20
[2026-03-11 12:17:05] [ 0.974649] Performance Events: unsupported p6 CPU model 154 no PMU driver, software events only.
[2026-03-11 12:17:05] [ 0.974649] signal: max sigframe size: 3632
[2026-03-11 12:17:05] [ 0.974649] rcu: Hierarchical SRCU implementation.
[2026-03-11 12:17:05] [ 0.974649] rcu: Max phase no-delay instances is 400.
[2026-03-11 12:17:05] [ 0.974649] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[2026-03-11 12:17:05] [ 0.974649] NMI watchdog: Perf NMI watchdog permanently disabled
[2026-03-11 12:17:05] [ 0.974649] smp: Bringing up secondary CPUs …
[2026-03-11 12:17:05] [ 0.974649] installing Xen timer for CPU 1
[2026-03-11 12:17:05] [ 0.974649] smpboot: x86: Booting SMP configuration:
[2026-03-11 12:17:05] [ 0.974649] … node #0, CPUs: #1
[2026-03-11 12:17:05] [ 0.974649] installing Xen timer for CPU 2
[2026-03-11 12:17:06] [ 0.974649] #2
[2026-03-11 12:17:06] [ 0.974741] installing Xen timer for CPU 3
[2026-03-11 12:17:06] [ 0.974796] #3
[2026-03-11 12:17:06] [ 0.974920] cpu 1 spinlock event irq 33
[2026-03-11 12:17:06] [ 0.974920] cpu 2 spinlock event irq 34
[2026-03-11 12:17:06] [ 0.975707] cpu 3 spinlock event irq 35
[2026-03-11 12:17:06] [ 0.975723] smp: Brought up 1 node, 4 CPUs
[2026-03-11 12:17:06] [ 0.975729] smpboot: Total of 4 processors activated (19967.95 BogoMIPS)
[2026-03-11 12:17:06] [ 0.975952] Memory: 11977772K/12287612K available (20480K kernel code, 4381K rwdata, 10076K rodata, 5604K init, 5896K bss, 301272K reserved, 0K cma-reserved)
[2026-03-11 12:17:06] [ 0.975967] devtmpfs: initialized
[2026-03-11 12:17:06] [ 0.975967] x86/mm: Memory block size: 128MB
[2026-03-11 12:17:06] [ 0.977190] resource: avoiding allocation from e820 entry [mem 0xfeff8000-0xfeffffff]
[2026-03-11 12:17:06] [ 0.977190] resource: remaining [mem 0x00000000fc008040-0x00000000feff7fff] available
[2026-03-11 12:17:06] [ 0.977190] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[2026-03-11 12:17:06] [ 0.977190] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[2026-03-11 12:17:06] [ 0.977689] pinctrl core: initialized pinctrl subsystem
[2026-03-11 12:17:06] [ 0.978100] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[2026-03-11 12:17:06] [ 0.978127] xen:grant_table: Grant tables using version 1 layout
[2026-03-11 12:17:06] [ 0.978151] Grant table initialized
[2026-03-11 12:17:06] [ 0.978249] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[2026-03-11 12:17:06] [ 0.978312] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[2026-03-11 12:17:06] [ 0.978326] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[2026-03-11 12:17:06] [ 0.978347] audit: initializing netlink subsys (disabled)
[2026-03-11 12:17:06] [ 0.978379] audit: type=2000 audit(1773245825.990:1): state=initialized audit_enabled=0 res=1
[2026-03-11 12:17:06] [ 0.978379] thermal_sys: Registered thermal governor ‘fair_share’
[2026-03-11 12:17:06] [ 0.978379] thermal_sys: Registered thermal governor ‘bang_bang’
[2026-03-11 12:17:06] [ 0.978379] thermal_sys: Registered thermal governor ‘step_wise’
[2026-03-11 12:17:06] [ 0.978379] thermal_sys: Registered thermal governor ‘user_space’
[2026-03-11 12:17:06] [ 0.978379] cpuidle: using governor menu
[2026-03-11 12:17:06] [ 0.978379] PCI: Fatal: No config space access function found
[2026-03-11 12:17:06] [ 0.978728] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[2026-03-11 12:17:06] [ 0.982741] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[2026-03-11 12:17:06] [ 0.982741] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[2026-03-11 12:17:06] [ 0.982741] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[2026-03-11 12:17:06] [ 0.982748] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[2026-03-11 12:17:06] [ 0.983089] cryptd: max_cpu_qlen set to 1000
[2026-03-11 12:17:06] [ 0.992731] raid6: skipped pq benchmark and selected avx2x4
[2026-03-11 12:17:06] [ 0.992731] raid6: using avx2x2 recovery algorithm
[2026-03-11 12:17:06] [ 0.992752] ACPI: Added _OSI(Module Device)
[2026-03-11 12:17:06] [ 0.992758] ACPI: Added _OSI(Processor Device)
[2026-03-11 12:17:06] [ 0.992765] ACPI: Added _OSI(Processor Aggregator Device)
[2026-03-11 12:17:06] [ 0.993958] ACPI: 1 ACPI AML tables successfully acquired and loaded
[2026-03-11 12:17:06] [ 0.994106] ACPI: OSL: SCI (ACPI GSI 9) not registered
[2026-03-11 12:17:06] [ 0.995387] ACPI: Interpreter enabled
[2026-03-11 12:17:06] [ 0.995397] ACPI: PM: (supports S0)
[2026-03-11 12:17:06] [ 0.995403] ACPI: Using platform specific model for interrupt routing
[2026-03-11 12:17:06] [ 0.995624] PCI: Using host bridge windows from ACPI; if necessary, use “pci=nocrs” and report a bug
[2026-03-11 12:17:06] [ 0.995636] PCI: Using E820 reservations for host bridge windows
[2026-03-11 12:17:06] [ 0.995649] ACPI: Enabled 1 GPEs in block 00 to 0F
[2026-03-11 12:17:06] [ 0.995649] ACPI Error: No handler or method for GPE 00, disabling event (20240827/evgpe-839)
[2026-03-11 12:17:06] [ 0.995649] ACPI Error: No handler or method for GPE 01, disabling event (20240827/evgpe-839)
[2026-03-11 12:17:06] [ 0.995654] ACPI Error: No handler or method for GPE 03, disabling event (20240827/evgpe-839)
[2026-03-11 12:17:06] [ 0.995654] ACPI Error: No handler or method for GPE 04, disabling event (20240827/evgpe-839)
[2026-03-11 12:17:06] [ 0.995654] ACPI Error: No handler or method for GPE 05, disabling event (20240827/evgpe-839)
[2026-03-11 12:17:06] [ 0.995654] ACPI Error: No handler or method for GPE 06, disabling event (20240827/evgpe-839)
[2026-03-11 12:17:06] [ 0.995654] ACPI Error: No handler or method for GPE 07, disabling event (20240827/evgpe-839)
[2026-03-11 12:17:06] [ 1.001729] xen:balloon: Initialising balloon driver
[2026-03-11 12:17:06] [ 1.002674] iommu: Default domain type: Translated
[2026-03-11 12:17:06] [ 1.002674] iommu: DMA domain TLB invalidation policy: lazy mode
[2026-03-11 12:17:06] [ 1.002726] SCSI subsystem initialized
[2026-03-11 12:17:06] [ 1.002740] ACPI: bus type USB registered
[2026-03-11 12:17:06] [ 1.002740] usbcore: registered new interface driver usbfs
[2026-03-11 12:17:06] [ 1.002740] usbcore: registered new interface driver hub
[2026-03-11 12:17:06] [ 1.002740] usbcore: registered new device driver usb
[2026-03-11 12:17:06] [ 1.002740] pps_core: LinuxPPS API ver. 1 registered
[2026-03-11 12:17:06] [ 1.002741] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[2026-03-11 12:17:06] [ 1.002754] PTP clock support registered
[2026-03-11 12:17:06] [ 1.002771] EDAC MC: Ver: 3.0.0
[2026-03-11 12:17:06] [ 1.002956] NetLabel: Initializing
[2026-03-11 12:17:06] [ 1.002956] NetLabel: domain hash size = 128
[2026-03-11 12:17:06] [ 1.002956] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[2026-03-11 12:17:06] [ 1.002956] NetLabel: unlabeled traffic allowed by default
[2026-03-11 12:17:06] [ 1.002956] mctp: management component transport protocol core
[2026-03-11 12:17:06] [ 1.002956] NET: Registered PF_MCTP protocol family
[2026-03-11 12:17:06] [ 1.002956] PCI: Using ACPI for IRQ routing
[2026-03-11 12:17:06] [ 1.002956] PCI: System does not support PCI
[2026-03-11 12:17:06] [ 1.002956] vgaarb: loaded
[2026-03-11 12:17:06] [ 1.002957] clocksource: Switched to clocksource tsc-early
[2026-03-11 12:17:06] [ 1.002957] VFS: Disk quotas dquot_6.6.0
[2026-03-11 12:17:06] [ 1.002957] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[2026-03-11 12:17:06] [ 1.002957] pnp: PnP ACPI init
[2026-03-11 12:17:06] [ 1.002957] pnp: PnP ACPI: found 0 devices
[2026-03-11 12:17:06] [ 1.003857] NET: Registered PF_INET protocol family
[2026-03-11 12:17:06] [ 1.003884] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[2026-03-11 12:17:06] [ 1.005542] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[2026-03-11 12:17:06] [ 1.005563] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[2026-03-11 12:17:06] [ 1.005577] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[2026-03-11 12:17:06] [ 1.005671] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[2026-03-11 12:17:06] [ 1.005834] TCP: Hash tables configured (established 131072 bind 65536)
[2026-03-11 12:17:06] [ 1.005877] MPTCP token hash table entries: 16384 (order: 7, 393216 bytes, linear)
[2026-03-11 12:17:06] [ 1.005921] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[2026-03-11 12:17:06] [ 1.005949] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[2026-03-11 12:17:06] [ 1.005998] NET: Registered PF_UNIX/PF_LOCAL protocol family
[2026-03-11 12:17:06] [ 1.006017] NET: Registered PF_XDP protocol family
[2026-03-11 12:17:06] [ 1.006026] PCI: CLS 0 bytes, default 64
[2026-03-11 12:17:06] [ 1.006066] Trying to unpack rootfs image as initramfs…
[2026-03-11 12:17:06] [ 1.007473] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[2026-03-11 12:17:06] [ 1.007483] software IO TLB: mapped [mem 0x00000000fbc00000-0x00000000fc000000] (4MB)
[2026-03-11 12:17:06] [ 1.007537] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x23fa717cb36, max_idle_ns: 440795237972 ns
[2026-03-11 12:17:06] [ 1.007590] clocksource: Switched to clocksource tsc
[2026-03-11 12:17:06] [ 1.012149] Initialise system trusted keyrings
[2026-03-11 12:17:06] [ 1.012185] Key type blacklist registered
[2026-03-11 12:17:06] [ 1.012835] Freeing initrd memory: 20096K
[2026-03-11 12:17:06] [ 1.178831] workingset: timestamp_bits=36 max_order=22 bucket_order=0
[2026-03-11 12:17:06] [ 1.178874] zbud: loaded
[2026-03-11 12:17:06] [ 1.179693] integrity: Platform Keyring initialized
[2026-03-11 12:17:06] [ 1.179717] integrity: Machine keyring initialized
[2026-03-11 12:17:06] [ 1.191079] NET: Registered PF_ALG protocol family
[2026-03-11 12:17:06] [ 1.191100] xor: automatically using best checksumming function avx
[2026-03-11 12:17:06] [ 1.191120] Key type asymmetric registered
[2026-03-11 12:17:06] [ 1.191132] Asymmetric key parser ‘x509’ registered
[2026-03-11 12:17:06] [ 1.193315] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[2026-03-11 12:17:06] [ 1.193418] io scheduler mq-deadline registered
[2026-03-11 12:17:06] [ 1.193435] io scheduler kyber registered
[2026-03-11 12:17:06] [ 1.193478] io scheduler bfq registered
[2026-03-11 12:17:06] [ 1.195334] atomic64_test: passed for x86-64 platform with CX8 and with SSE
[2026-03-11 12:17:06] [ 1.199032] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[2026-03-11 12:17:06] [ 1.201477] Non-volatile memory driver v1.3
[2026-03-11 12:17:06] [ 1.201496] Linux agpgart interface v0.103
[2026-03-11 12:17:06] [ 1.201563] ACPI: bus type drm_connector registered
[2026-03-11 12:17:06] [ 1.202273] usbcore: registered new interface driver usbserial_generic
[2026-03-11 12:17:06] [ 1.202297] usbserial: USB Serial support registered for generic
[2026-03-11 12:17:06] [ 1.202329] i8042: PNP: No PS/2 controller found.
[2026-03-11 12:17:06] [ 1.202393] mousedev: PS/2 mouse device common for all mice
[2026-03-11 12:17:06] [ 1.202503] device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
[2026-03-11 12:17:06] [ 1.202537] device-mapper: uevent: version 1.0.3
[2026-03-11 12:17:06] [ 1.202620] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@lists.linux.dev
[2026-03-11 12:17:06] [ 1.202727] intel_pstate: CPU model not supported
[2026-03-11 12:17:06] [ 1.202765] hid: raw HID events driver (C) Jiri Kosina
[2026-03-11 12:17:06] [ 1.202812] usbcore: registered new interface driver usbhid
[2026-03-11 12:17:06] [ 1.202828] usbhid: USB HID core driver
[2026-03-11 12:17:06] [ 1.202906] drop_monitor: Initializing network drop monitor service
[2026-03-11 12:17:06] [ 1.202998] Initializing XFRM netlink socket
[2026-03-11 12:17:06] [ 1.203036] NET: Registered PF_INET6 protocol family
[2026-03-11 12:17:06] [ 1.204938] Segment Routing with IPv6
[2026-03-11 12:17:06] [ 1.204954] RPL Segment Routing with IPv6
[2026-03-11 12:17:06] [ 1.204976] In-situ OAM (IOAM) with IPv6
[2026-03-11 12:17:06] [ 1.205006] mip6: Mobile IPv6
[2026-03-11 12:17:06] [ 1.205021] NET: Registered PF_PACKET protocol family
[2026-03-11 12:17:06] [ 1.205488] IPI shorthand broadcast: enabled
[2026-03-11 12:17:06] [ 1.205639] AES CTR mode by8 optimization enabled
[2026-03-11 12:17:06] [ 1.207626] sched_clock: Marking stable (1206006335, 1450992)->(1401934901, -194477574)
[2026-03-11 12:17:06] [ 1.207921] registered taskstats version 1
[2026-03-11 12:17:06] [ 1.208305] Loading compiled-in X.509 certificates
[2026-03-11 12:17:06] [ 1.217931] Loaded X.509 cert ‘Build time autogenerated kernel key: b70ea4bb53efdfee4edd55ecad339d4de464a3c4’
[2026-03-11 12:17:06] [ 1.222197] Demotion targets for Node 0: null
[2026-03-11 12:17:06] [ 1.222215] page_owner is disabled
[2026-03-11 12:17:06] [ 1.222492] Key type .fscrypt registered
[2026-03-11 12:17:06] [ 1.222504] Key type fscrypt-provisioning registered
[2026-03-11 12:17:06] [ 1.222839] Btrfs loaded, zoned=yes, fsverity=yes
[2026-03-11 12:17:06] [ 1.222880] Key type big_key registered
[2026-03-11 12:17:06] [ 1.228715] Key type encrypted registered
[2026-03-11 12:17:06] [ 1.228739] ima: No TPM chip found, activating TPM-bypass!
[2026-03-11 12:17:06] [ 1.228760] Loading compiled-in module X.509 certificates
[2026-03-11 12:17:06] [ 1.229326] Loaded X.509 cert ‘Build time autogenerated kernel key: b70ea4bb53efdfee4edd55ecad339d4de464a3c4’
[2026-03-11 12:17:06] [ 1.229356] ima: Allocated hash algorithm: sha256
[2026-03-11 12:17:06] [ 1.229381] ima: No architecture policies found
[2026-03-11 12:17:06] [ 1.229408] evm: Initialising EVM extended attributes:
[2026-03-11 12:17:06] [ 1.229422] evm: security.selinux
[2026-03-11 12:17:06] [ 1.229433] evm: security.SMACK64 (disabled)
[2026-03-11 12:17:06] [ 1.229447] evm: security.SMACK64EXEC (disabled)
[2026-03-11 12:17:06] [ 1.229476] evm: security.SMACK64TRANSMUTE (disabled)
[2026-03-11 12:17:06] [ 1.229490] evm: security.SMACK64MMAP (disabled)
[2026-03-11 12:17:06] [ 1.229504] evm: security.apparmor
[2026-03-11 12:17:06] [ 1.229514] evm: security.ima
[2026-03-11 12:17:06] [ 1.229525] evm: security.capability
[2026-03-11 12:17:06] [ 1.229535] evm: HMAC attrs: 0x1
[2026-03-11 12:17:06] [ 1.233727] alg: No test for 842 (842-scomp)
[2026-03-11 12:17:06] [ 1.233825] alg: No test for 842 (842-generic)
[2026-03-11 12:17:06] [ 1.235494] xenbus_probe_frontend: Device with no driver: device/vbd/51712
[2026-03-11 12:17:06] [ 1.235517] xenbus_probe_frontend: Device with no driver: device/vbd/51728
[2026-03-11 12:17:06] [ 1.379537] xenbus_probe_frontend: Device with no driver: device/vbd/51744
[2026-03-11 12:17:06] [ 1.379570] xenbus_probe_frontend: Device with no driver: device/vbd/51760
[2026-03-11 12:17:06] [ 1.379590] xenbus_probe_frontend: Device with no driver: device/vif/0
[2026-03-11 12:17:06] [ 1.379671] RAS: Correctable Errors collector initialized.
[2026-03-11 12:17:06] [ 1.379742] clk: Disabling unused clocks
[2026-03-11 12:17:06] [ 1.379757] PM: genpd: Disabling unused power domains
[2026-03-11 12:17:06] [ 1.381320] Freeing unused decrypted memory: 2028K
[2026-03-11 12:17:06] [ 1.382431] Freeing unused kernel image (initmem) memory: 5604K
[2026-03-11 12:17:06] [ 1.382502] Write protecting the kernel read-only data: 30720k
[2026-03-11 12:17:06] [ 1.382837] Freeing unused kernel image (rodata/data gap) memory: 164K
[2026-03-11 12:17:06] [ 1.382864] Run /init as init process
[2026-03-11 12:17:06] Qubes initramfs script here:
[2026-03-11 12:17:06] [ 1.400937] blkfront: xvda: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
[2026-03-11 12:17:06] [ 1.403339] xvda: xvda1 xvda2 xvda3
[2026-03-11 12:17:06] [ 1.406672] blkfront: xvdb: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
[2026-03-11 12:17:06] [ 1.408770] blkfront: xvdc: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
[2026-03-11 12:17:06] [ 1.410699] blkfront: xvdd: barrier or flush: disabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
[2026-03-11 12:17:06] Waiting for /dev/xvda* devices…
[2026-03-11 12:17:06] Qubes: Doing R/W setup for TemplateVM…
[2026-03-11 12:17:06] [ 1.768508] xvdc: xvdc1 xvdc3
[2026-03-11 12:17:06] Setting up swapspace version 1, size = 1073737728 bytes
[2026-03-11 12:17:06] UUID=69170d3f-2228-46c5-838a-15cd4cdff486
[2026-03-11 12:17:06] Qubes: done.
[2026-03-11 12:17:07] [ 1.863981] EXT4-fs (xvda3): mounted filesystem c526cc6d-e7ca-4b10-aa38-8d5ebb919c70 r/w with ordered data mode. Quota mode: none.
[2026-03-11 12:17:07] Waiting for /dev/xvdd device…
[2026-03-11 12:17:07] [ 1.866989] EXT4-fs (xvdd): mounting ext3 file system using the ext4 subsystem
[2026-03-11 12:17:07] [ 1.867792] EXT4-fs (xvdd): mounted filesystem 134679b4-b870-4882-b79e-872e3badc2c7 ro with ordered data mode. Quota mode: none.
[2026-03-11 12:17:07] mount: can’t read ‘/proc/mounts’: No such file or directory
[2026-03-11 12:17:07] [ 1.942655] audit: type=1404 audit(1773245826.954:2): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295 enabled=1 old-enabled=1 lsm=selinux res=1
[2026-03-11 12:17:07] [ 1.975191] SELinux: policy capability network_peer_controls=1
[2026-03-11 12:17:07] [ 1.975219] SELinux: policy capability open_perms=1
[2026-03-11 12:17:07] [ 1.975233] SELinux: policy capability extended_socket_class=1
[2026-03-11 12:17:07] [ 1.975251] SELinux: policy capability always_check_network=0
[2026-03-11 12:17:07] [ 1.975267] SELinux: policy capability cgroup_seclabel=1
[2026-03-11 12:17:07] [ 1.975280] SELinux: policy capability nnp_nosuid_transition=1
[2026-03-11 12:17:07] [ 1.975297] SELinux: policy capability genfs_seclabel_symlinks=1
[2026-03-11 12:17:07] [ 1.975313] SELinux: policy capability ioctl_skip_cloexec=0
[2026-03-11 12:17:07] [ 1.975330] SELinux: policy capability userspace_initial_context=0
[2026-03-11 12:17:07] [ 2.001115] audit: type=1403 audit(1773245827.012:3): auid=4294967295 ses=4294967295 lsm=selinux res=1
[2026-03-11 12:17:07] [ 2.002928] systemd[1]: Successfully loaded SELinux policy in 60.865ms.
[2026-03-11 12:17:07] [ 2.089039] systemd[1]: Relabeled /dev/, /dev/shm/, /run/ in 9.348ms.
[2026-03-11 12:17:07] .[!p.]104.[?7h[ 2.097909] systemd[1]: systemd 256.17-1.fc41 running in system mode (+PAM +AUDIT +SELINUX -APPARMOR +IMA +SMACK +SECCOMP -GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN -IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT +LIBARCHIVE)
[2026-03-11 12:17:07] [ 2.098023] systemd[1]: Detected virtualization xen.
[2026-03-11 12:17:07] [ 2.098068] systemd[1]: Detected architecture x86-64.
[2026-03-11 12:17:07] Welcome to .[0;38;2;60;110;180mFedora Linux 41 (Forty One).[0m!
[2026-03-11 12:17:07] [.[0;1;31m !! .[0m] This OS version (Fedora Linux 41 (Forty One)) is past its end-of-support date (2025-12-15)
[2026-03-11 12:17:07] [ 2.101317] systemd[1]: No hostname configured, using default hostname.
[2026-03-11 12:17:07] [ 2.101436] systemd[1]: Hostname set to .
[2026-03-11 12:17:07] [ 2.161910] systemd[1]: bpf-restrict-fs: BPF LSM hook not enabled in the kernel, BPF LSM not supported.
[2026-03-11 12:17:07] [ 2.394489] systemd[1]: /usr/lib/systemd/system/qubes-gui-agent.service:15: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[2026-03-11 12:17:07] [ 2.467581] systemd[1]: Queued start job for default target multi-user.target.
[2026-03-11 12:17:07] [ 2.491405] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[2026-03-11 12:17:07] [.[0;32m OK .[0m] Created slice .[0;1;39msystem-getty.slice.[0m - Slice /system/getty.
[2026-03-11 12:17:07] [ 2.492226] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[2026-03-11 12:17:07] [.[0;32m OK .[0m] Created slice .[0;1;39msystem-modprobe.slice.[0m - Slice /system/modprobe.
[2026-03-11 12:17:07] [ 2.492822] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[2026-03-11 12:17:07] [.[0;32m OK .[0m] Created slice .[0;1;39msystem-serial\x2dget…slice.[0m - Slice /system/serial-getty.
[2026-03-11 12:17:07] [ 2.493282] systemd[1]: Created slice user.slice - User and Session Slice.
[2026-03-11 12:17:07] [.[0;32m OK .[0m] Created slice .[0;1;39muser.slice.[0m - User and Session Slice.
[2026-03-11 12:17:07] [ 2.493536] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
[2026-03-11 12:17:07] [.[0;32m OK .[0m] Started .[0;1;39msystemd-ask-password-conso….[0mequests to Console Directory Watch.
[2026-03-11 12:17:07] [ 2.493797] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[2026-03-11 12:17:07] [.[0;32m OK .[0m] Started .[0;1;39msystemd-ask-password-wall.….[0md Requests to Wall Directory Watch.
[2026-03-11 12:17:07] [ 2.494808] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[2026-03-11 12:17:07] [.[0;32m OK .[0m] Set up automount .[0;1;39mproc-sys-fs-binfm….[0mormats File System Automount Point.
[2026-03-11 12:17:07] [ 2.494974] systemd[1]: Expecting device dev-hvc0.device - /dev/hvc0…
[2026-03-11 12:17:07] Expecting device .[0;1;39mdev-hvc0.device.[0m - /dev/hvc0…
[2026-03-11 12:17:07] [ 2.495081] systemd[1]: Expecting device dev-xvdc1.device - /dev/xvdc1…
[2026-03-11 12:17:07] Expecting device .[0;1;39mdev-xvdc1.device.[0m - /dev/xvdc1…
[2026-03-11 12:17:07] [ 2.495187] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
[2026-03-11 12:17:07] [.[0;32m OK .[0m] Reached target .[0;1;39mcryptsetup.target.[0m - Local Encrypted Volumes.
[2026-03-11 12:17:07] [ 2.495301] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
[2026-03-11 12:17:07] [.[0;32m OK .[0m] Reached target .[0;1;39mintegritysetup.targ….[0m Local Integrity Protected Volumes.
[2026-03-11 12:17:07] [ 2.495436] systemd[1]: Reached target remote-cryptsetup.target - Remote Encrypted Volumes.
[2026-03-11 12:17:07] [.[0;32m OK .[0m] Reached target .[0;1;39mremote-cryptsetup.target.[0m - Remote Encrypted Volumes.
[2026-03-11 12:17:07] [ 2.495572] systemd[1]: Reached target remote-fs.target - Remote File Systems.
[2026-03-11 12:17:07] [.[0;32m OK .[0m] Reached target .[0;1;39mremote-fs.target.[0m - Remote File Systems.
[2026-03-11 12:17:07] [ 2.495690] systemd[1]: Reached target slices.target - Slice Units.
[2026-03-11 12:17:07] [.[0;32m OK .[0m] Reached target .[0;1;39mslices.target.[0m - Slice Units.
[2026-03-11 12:17:07] [ 2.495830] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
[2026-03-11 12:17:07] [.[0;32m OK .[0m] Reached target .[0;1;39mveritysetup.target.[0m - Local Verity Protected Volumes.
[2026-03-11 12:17:07] [ 2.499446] systemd[1]: Listening on systemd-coredump.socket - Process Core Dump Socket.
[2026-03-11 12:17:07] [.[0;32m OK .[0m] Listening on .[0;1;39msystemd-coredump.socket.[0m - Process Core Dump Socket.
[2026-03-11 12:17:07] [ 2.501235] systemd[1]: Listening on systemd-creds.socket - Credential Encryption/Decryption.
[2026-03-11 12:17:07] [.[0;32m OK .[0m] Listening on .[0;1;39msystemd-creds.socket.[0m - Credential Encryption/Decryption.
[2026-03-11 12:17:07] [ 2.501644] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[2026-03-11 12:17:07] [.[0;32m OK .[0m] Listening on .[0;1;39msystemd-initctl.socke….[0m- initctl Compatibility Named Pipe.
[2026-03-11 12:17:07] [ 2.502406] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
[2026-03-11 12:17:07] [.[0;32m OK .[0m] Listening on .[0;1;39msystemd-journald-audit.socket.[0m - Journal Audit Socket.
[2026-03-11 12:17:07] [ 2.503053] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[2026-03-11 12:17:07] [.[0;32m OK .[0m] Listening on .[0;1;39msystemd-journald-dev-…socket.[0m - Journal Socket (/dev/log).
[2026-03-11 12:17:07] [ 2.595115] systemd[1]: Listening on systemd-journald.socket - Journal Sockets.
[2026-03-11 12:17:07] [.[0;32m OK .[0m] Listening on .[0;1;39msystemd-journald.socket.[0m - Journal Sockets.
[2026-03-11 12:17:07] [ 2.595802] systemd[1]: Listening on systemd-oomd.socket - Userspace Out-Of-Memory (OOM) Killer Socket.
[2026-03-11 12:17:07] [.[0;32m OK .[0m] Listening on .[0;1;39msystemd-oomd.socket.[0m -… Out-Of-Memory (OOM) Killer Socket.
[2026-03-11 12:17:07] [ 2.595970] systemd[1]: systemd-pcrextend.socket - TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[2026-03-11 12:17:07] [ 2.596035] systemd[1]: systemd-pcrlock.socket - Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[2026-03-11 12:17:07] [ 2.597478] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[2026-03-11 12:17:07] [.[0;32m OK .[0m] Listening on .[0;1;39msystemd-udevd-control.socket.[0m - udev Control Socket.
[2026-03-11 12:17:07] [ 2.597957] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[2026-03-11 12:17:07] [.[0;32m OK .[0m] Listening on .[0;1;39msystemd-udevd-kernel.socket.[0m - udev Kernel Socket.
[2026-03-11 12:17:07] [ 2.600064] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System…
[2026-03-11 12:17:07] Mounting .[0;1;39mdev-hugepages.mount.[0m - Huge Pages File System…
[2026-03-11 12:17:07] [ 2.601233] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System…
[2026-03-11 12:17:07] Mounting .[0;1;39mdev-mqueue.mount.[0m - POSIX Message Queue File System…
[2026-03-11 12:17:07] [ 2.602351] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System…
[2026-03-11 12:17:07] Mounting .[0;1;39msys-kernel-debug.mount.[0m - Kernel Debug File System…
[2026-03-11 12:17:07] [ 2.604573] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System…
[2026-03-11 12:17:07] Mounting .[0;1;39msys-kernel-tracing.mount.[0m - Kernel Trace File System…
[2026-03-11 12:17:07] [ 2.605979] systemd[1]: Starting dev-xvdc1-swap.service - Enable swap on /dev/xvdc1 early…
[2026-03-11 12:17:07] Starting .[0;1;39mdev-xvdc1-swap.service.[0m - Enable swap on /dev/xvdc1 early…
[2026-03-11 12:17:07] [ 2.623642] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes…
[2026-03-11 12:17:07] Starting .[0;1;39mkmod-static-nodes.service.[0m…eate List of Static Device Nodes…
[2026-03-11 12:17:07] [ 2.626597] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs…
[2026-03-11 12:17:07] Starting .[0;1;39mmodprobe@configfs.service.[0m - Load Kernel Module configfs…
[2026-03-11 12:17:07] [ 2.628220] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod…
[2026-03-11 12:17:07] [ 2.628338] Adding 1048572k swap on /dev/xvdc1. Priority:-2 extents:1 across:1048572k SS
[2026-03-11 12:17:07] Starting .[0;1;39mmodprobe@dm_mod.service.[0m - Load Kernel Module dm_mod…
[2026-03-11 12:17:07] [ 2.632330] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm…
[2026-03-11 12:17:07] Starting .[0;1;39mmodprobe@drm.service.[0m - Load Kernel Module drm…
[2026-03-11 12:17:07] [ 2.633673] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore…
[2026-03-11 12:17:07] Starting .[0;1;39mmodprobe@efi_pstore.servi….[0m - Load Kernel Module efi_pstore…
[2026-03-11 12:17:07] [ 2.635716] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse…
[2026-03-11 12:17:07] Starting .[0;1;39mmodprobe@fuse.service.[0m - Load Kernel Module fuse…
[2026-03-11 12:17:07] [ 2.637650] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop…
[2026-03-11 12:17:07] Starting .[0;1;39mmodprobe@loop.service.[0m - Load Kernel Module loop…
[2026-03-11 12:17:07] [ 2.638018] systemd[1]: systemd-hibernate-clear.service - Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
[2026-03-11 12:17:07] [ 2.801156] loop: module loaded
[2026-03-11 12:17:07] [ 2.807261] fuse: init (API version 7.41)
[2026-03-11 12:17:07] [ 2.809845] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules…
[2026-03-11 12:17:07] Starting .[0;1;39msystemd-modules-load.service.[0m - Load Kernel Modules…
[2026-03-11 12:17:07] [ 2.810958] systemd[1]: Starting systemd-network-generator.service - Generate network units from Kernel command line…
[2026-03-11 12:17:07] Starting .[0;1;39msystemd-network-generator….[0mk units from Kernel command line…
[2026-03-11 12:17:07] [ 2.811120] systemd[1]: systemd-pcrmachine.service - TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[2026-03-11 12:17:07] [ 2.811256] systemd[1]: systemd-tpm2-setup-early.service - Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[2026-03-11 12:17:08] [ 2.812276] systemd[1]: Starting systemd-udev-load-credentials.service - Load udev Rules from Credentials…
[2026-03-11 12:17:08] Starting .[0;1;39msystemd-udev-load-credent….[0mLoad udev Rules from Credentials…
[2026-03-11 12:17:08] [ 2.813395] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices…
[2026-03-11 12:17:08] Starting .[0;1;39msystemd-udev-trigger.service.[0m - Coldplug All udev Devices…
[2026-03-11 12:17:08] [ 2.815115] systemd[1]: Condition check resulted in dev-xvdc1.swap - /dev/xvdc1 being skipped.
[2026-03-11 12:17:08] [ 2.815200] systemd[1]: Unnecessary job was removed for dev-xvdc1.device - /dev/xvdc1.
[2026-03-11 12:17:08] [ 2.818864] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
[2026-03-11 12:17:08] [.[0;32m OK .[0m] Mounted .[0;1;39mdev-hugepages.mount.[0m - Huge Pages File System.
[2026-03-11 12:17:08] [ 2.819164] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[2026-03-11 12:17:08] [.[0;32m OK .[0m] Mounted .[0;1;39mdev-mqueue.mount.[0m - POSIX Message Queue File System.
[2026-03-11 12:17:08] [ 2.819498] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
[2026-03-11 12:17:08] [.[0;32m OK .[0m] Mounted .[0;1;39msys-kernel-debug.mount.[0m - Kernel Debug File System.
[2026-03-11 12:17:08] [ 2.819723] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
[2026-03-11 12:17:08] [.[0;32m OK .[0m] Mounted .[0;1;39msys-kernel-tracing.mount.[0m - Kernel Trace File System.
[2026-03-11 12:17:08] [ 2.820114] systemd[1]: dev-xvdc1-swap.service: Deactivated successfully.
[2026-03-11 12:17:08] [ 2.820358] systemd[1]: Finished dev-xvdc1-swap.service - Enable swap on /dev/xvdc1 early.
[2026-03-11 12:17:08] [.[0;32m OK .[0m] Finished .[0;1;39mdev-xvdc1-swap.service.[0m - Enable swap on /dev/xvdc1 early.
[2026-03-11 12:17:08] [ 2.820885] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
[2026-03-11 12:17:08] [.[0;32m OK .[0m] Finished .[0;1;39mkmod-static-nodes.service.[0m…Create List of Static Device Nodes.
[2026-03-11 12:17:08] [ 2.821263] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[2026-03-11 12:17:08] [ 2.821538] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
[2026-03-11 12:17:08] [.[0;32m OK .[0m] Finished .[0;1;39mmodprobe@configfs.service.[0m - Load Kernel Module configfs.
[2026-03-11 12:17:08] [ 2.821934] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[2026-03-11 12:17:08] [ 2.822142] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
[2026-03-11 12:17:08] [.[0;32m OK .[0m] Finished .[0;1;39mmodprobe@dm_mod.service.[0m - Load Kernel Module dm_mod.
[2026-03-11 12:17:08] [ 2.823087] systemd[1]: modprobe@drm.service: Deactivated successfully.
[2026-03-11 12:17:08] [ 2.823283] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
[2026-03-11 12:17:08] [.[0;32m OK .[0m] Finished .[0;1;39mmodprobe@drm.service.[0m - Load Kernel Module drm.
[2026-03-11 12:17:08] [ 2.823672] i2c_dev: i2c /dev entries driver
[2026-03-11 12:17:08] [ 2.823742] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[2026-03-11 12:17:08] [ 2.823939] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[2026-03-11 12:17:08] [.[0;32m OK .[0m] Finished .[0;1;39mmodprobe@efi_pstore.service.[0m - Load Kernel Module efi_pstore.
[2026-03-11 12:17:08] [ 2.996939] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[2026-03-11 12:17:08] [ 2.997199] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
[2026-03-11 12:17:08] [.[0;32m OK .[0m] Finished .[0;1;39mmodprobe@fuse.service.[0m - Load Kernel Module fuse.
[2026-03-11 12:17:08] [ 2.997519] xen:xen_evtchn: Event-channel device installed
[2026-03-11 12:17:08] [ 2.997646] systemd[1]: modprobe@loop.service: Deactivated successfully.
[2026-03-11 12:17:08] [ 2.997877] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
[2026-03-11 12:17:08] [.[0;32m OK .[0m] Finished .[0;1;39mmodprobe@loop.service.[0m - Load Kernel Module loop.
[2026-03-11 12:17:08] [ 2.998392] systemd[1]: Finished systemd-network-generator.service - Generate network units from Kernel command line.
[2026-03-11 12:17:08] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-network-generator….[0mork units from Kernel command line.
[2026-03-11 12:17:08] [ 2.999018] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices.
[2026-03-11 12:17:08] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-udev-trigger.service.[0m - Coldplug All udev Devices.
[2026-03-11 12:17:08] [ 2.999543] systemd[1]: Finished systemd-udev-load-credentials.service - Load udev Rules from Credentials.
[2026-03-11 12:17:08] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-udev-load-credent….[0m- Load udev Rules from Credentials.
[2026-03-11 12:17:08] [ 2.999907] systemd[1]: Reached target swap.target - Swaps.
[2026-03-11 12:17:08] [.[0;32m OK .[0m] Reached target .[0;1;39mswap.target.[0m - Swaps.
[2026-03-11 12:17:08] [ 3.001357] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System…
[2026-03-11 12:17:08] Mounting .[0;1;39msys-fs-fuse-connections.mount.[0m - FUSE Control File System…
[2026-03-11 12:17:08] [ 3.003552] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System…
[2026-03-11 12:17:08] Mounting .[0;1;39msys-kernel-config.mount.[0m - Kernel Configuration File System…
[2026-03-11 12:17:08] [ 3.009685] systemd[1]: Mounting tmp.mount - Temporary Directory /tmp…
[2026-03-11 12:17:08] Mounting .[0;1;39mtmp.mount.[0m - Temporary Directory /tmp…
[2026-03-11 12:17:08] [ 3.009769] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[2026-03-11 12:17:08] [ 3.010494] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems…
[2026-03-11 12:17:08] Starting .[0;1;39msystemd-remount-fs.servic….[0munt Root and Kernel File Systems…
[2026-03-11 12:17:08] [ 3.010583] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
[2026-03-11 12:17:08] [ 3.012539] systemd[1]: Starting systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully…
[2026-03-11 12:17:08] Starting .[0;1;39msystemd-tmpfiles-setup-de….[0m Device Nodes in /dev gracefully…
[2026-03-11 12:17:08] [ 3.013039] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
[2026-03-11 12:17:08] [.[0;32m OK .[0m] Mounted .[0;1;39msys-fs-fuse-connections.mount.[0m - FUSE Control File System.
[2026-03-11 12:17:08] [ 3.013148] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
[2026-03-11 12:17:08] [.[0;32m OK .[0m] Mounted .[0;1;39msys-kernel-config.mount.[0m - Kernel Configuration File System.
[2026-03-11 12:17:08] [ 3.015442] systemd[1]: Mounted tmp.mount - Temporary Directory /tmp.
[2026-03-11 12:17:08] [.[0;32m OK .[0m] Mounted .[0;1;39mtmp.mount.[0m - Temporary Directory /tmp.
[2026-03-11 12:17:08] [ 3.028399] EXT4-fs (xvda3): re-mounted c526cc6d-e7ca-4b10-aa38-8d5ebb919c70.
[2026-03-11 12:17:08] [ 3.029409] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
[2026-03-11 12:17:08] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-remount-fs.servic….[0mmount Root and Kernel File Systems.
[2026-03-11 12:17:08] [ 3.203781] systemd[1]: ostree-remount.service - OSTree Remount OS/ Bind Mounts was skipped because of an unmet condition check (ConditionKernelCommandLine=ostree).
[2026-03-11 12:17:08] [ 3.204652] systemd[1]: systemd-hwdb-update.service - Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
[2026-03-11 12:17:08] [ 3.204758] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
[2026-03-11 12:17:08] [ 3.204841] systemd[1]: systemd-tpm2-setup.service - TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[2026-03-11 12:17:08] [ 3.210123] Rounding down aligned max_sectors from 4294967295 to 4294967288
[2026-03-11 12:17:08] [ 3.210225] db_root: cannot open: /etc/target
[2026-03-11 12:17:08] [ 3.240051] systemd[1]: Finished systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully.
[2026-03-11 12:17:08] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-tmpfiles-setup-de….[0mic Device Nodes in /dev gracefully.
[2026-03-11 12:17:08] [ 3.240432] systemd[1]: systemd-sysusers.service - Create System Users was skipped because no trigger condition checks were met.
[2026-03-11 12:17:08] [ 3.241733] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev…
[2026-03-11 12:17:08] Starting .[0;1;39msystemd-tmpfiles-setup-de….[0meate Static Device Nodes in /dev…
[2026-03-11 12:17:08] [ 3.258833] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
[2026-03-11 12:17:08] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-modules-load.service.[0m - Load Kernel Modules.
[2026-03-11 12:17:08] [ 3.261841] systemd[1]: Starting qubes-db.service - Qubes DB agent…
[2026-03-11 12:17:08] Starting .[0;1;39mqubes-db.service.[0m - Qubes DB agent…
[2026-03-11 12:17:08] [ 3.263546] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables…
[2026-03-11 12:17:08] Starting .[0;1;39msystemd-sysctl.service.[0m - Apply Kernel Variables…
[2026-03-11 12:17:08] [ 3.276719] systemd[1]: Started qubes-db.service - Qubes DB agent.
[2026-03-11 12:17:08] [.[0;32m OK .[0m] Started .[0;1;39mqubes-db.service.[0m - Qubes DB agent.
[2026-03-11 12:17:08] [ 3.278090] systemd[1]: Starting qubes-sysinit.service - Init Qubes Services settings…
[2026-03-11 12:17:08] Starting .[0;1;39mqubes-sysinit.service.[0m - Init Qubes Services settings…
[2026-03-11 12:17:08] [ 3.279163] systemd[1]: Starting systemd-random-seed.service - Load/Save OS Random Seed…
[2026-03-11 12:17:08] Starting .[0;1;39msystemd-random-seed.service.[0m - Load/Save OS Random Seed…
[2026-03-11 12:17:08] [ 3.290694] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
[2026-03-11 12:17:08] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-sysctl.service.[0m - Apply Kernel Variables.
[2026-03-11 12:17:08] [ 3.305661] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
[2026-03-11 12:17:08] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-tmpfiles-setup-de….[0mCreate Static Device Nodes in /dev.
[2026-03-11 12:17:08] [ 3.306137] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
[2026-03-11 12:17:08] [.[0;32m OK .[0m] Reached target .[0;1;39mlocal-fs-pre.target.[0m…Preparation for Local File Systems.
[2026-03-11 12:17:08] [ 3.306561] systemd[1]: Set up automount efi.automount - EFI System Partition Automount.
[2026-03-11 12:17:08] [.[0;32m OK .[0m] Set up automount .[0;1;39mefi.automount.[0m - EFI System Partition Automount.
[2026-03-11 12:17:08] [ 3.308355] systemd[1]: Started haveged.service - Entropy Daemon based on the HAVEGE algorithm.
[2026-03-11 12:17:08] [.[0;32m OK .[0m] Started .[0;1;39mhaveged.service.[0m - Entropy …emon based on the HAVEGE algorithm.
[2026-03-11 12:17:08] [ 3.310292] systemd[1]: Starting systemd-journald.service - Journal Service…
[2026-03-11 12:17:08] Starting .[0;1;39msystemd-journald.service.[0m - Journal Service…
[2026-03-11 12:17:08] [ 3.312178] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files…
[2026-03-11 12:17:08] Starting .[0;1;39msystemd-udevd.service.[0m - R…ager for Device Events and Files…
[2026-03-11 12:17:08] [ 3.406495] systemd[1]: Finished systemd-random-seed.service - Load/Save OS Random Seed.
[2026-03-11 12:17:08] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-random-seed.service.[0m - Load/Save OS Random Seed.
[2026-03-11 12:17:08] [ 3.414338] systemd-journald[359]: Collecting audit messages is enabled.
[2026-03-11 12:17:08] [ 3.424626] systemd[1]: Started systemd-journald.service - Journal Service.
[2026-03-11 12:17:08] [.[0;32m OK .[0m] Started .[0;1;39msystemd-journald.service.[0m - Journal Service.
[2026-03-11 12:17:08] [ 3.425272] audit: type=1130 audit(1773245828.436:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg=‘unit=systemd-journald comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[2026-03-11 12:17:08] [.[0;32m OK .[0m] Finished .[0;1;39mqubes-sysinit.service.[0m - Init Qubes Services settings.
[2026-03-11 12:17:08] [ 3.432580] audit: type=1130 audit(1773245828.444:5): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg=‘unit=qubes-sysinit comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[2026-03-11 12:17:08] Starting .[0;1;39mqubes-mount-dirs.service.[0m …itialize and mount /rw and /home…
[2026-03-11 12:17:08] Starting .[0;1;39mqubes-rootfs-resize.service.[0m - Adjust root filesystem size…
[2026-03-11 12:17:08] Starting .[0;1;39msystemd-journal-flush.ser….[0msh Journal to Persistent Storage…
[2026-03-11 12:17:08] [ 3.457721] systemd-journald[359]: Received client request to flush runtime journal.
[2026-03-11 12:17:08] [.[0;32m OK .[0m] Started .[0;1;39msystemd-udevd.service.[0m - Ru…anager for Device Events and Files.
[2026-03-11 12:17:08] [ 3.506520] audit: type=1130 audit(1773245828.516:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg=‘unit=systemd-udevd comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[2026-03-11 12:17:08] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-journal-flush.ser….[0mlush Journal to Persistent Storage.
[2026-03-11 12:17:08] [ 3.596216] audit: type=1130 audit(1773245828.607:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg=‘unit=systemd-journal-flush comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[2026-03-11 12:17:08] [.[0;32m OK .[0m] Found device .[0;1;39mdev-hvc0.device.[0m - /dev/hvc0.
[2026-03-11 12:17:08] [.[0;32m OK .[0m] Finished .[0;1;39mqubes-rootfs-resize.service.[0m - Adjust root filesystem size.
[2026-03-11 12:17:08] [ 3.654952] audit: type=1130 audit(1773245828.666:8): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg=‘unit=qubes-rootfs-resize comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[2026-03-11 12:17:08] [ 3.793618] input: PC Speaker as /devices/platform/pcspkr/input/input0
[2026-03-11 12:17:09] [ 3.863069] xen_netfront: Initialising Xen virtual ethernet driver
[2026-03-11 12:17:09] [ 3.866782] xen_netfront: backend supports XDP headroom
[2026-03-11 12:17:09] [ 3.866808] vif vif-0: bouncing transmitted data to zeroed pages
[2026-03-11 12:17:09] Starting .[0;1;39mdev-xvdc1-swap.service.[0m - Enable swap on /dev/xvdc1 early…
[2026-03-11 12:17:09] Starting .[0;1;39mmodprobe@dm_mod.service.[0m - Load Kernel Module dm_mod…
[2026-03-11 12:17:09] Starting .[0;1;39mmodprobe@efi_pstore.servi….[0m - Load Kernel Module efi_pstore…
[2026-03-11 12:17:09] Starting .[0;1;39mmodprobe@loop.service.[0m - Load Kernel Module loop…
[2026-03-11 12:17:09] [.[0;32m OK .[0m] Created slice .[0;1;39msystem-qubes\x2dnetw….[0mSlice /system/qubes-network-uplink.
[2026-03-11 12:17:09] Starting .[0;1;39msystemd-vconsole-setup.service.[0m - Virtual Console Setup…
[2026-03-11 12:17:09] [.[0;32m OK .[0m] Finished .[0;1;39mdev-xvdc1-swap.service.[0m - Enable swap on /dev/xvdc1 early.
[2026-03-11 12:17:09] [ 3.925365] audit: type=1130 audit(1773245828.936:9): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg=‘unit=dev-xvdc1-swap comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[2026-03-11 12:17:09] [ 3.925480] audit: type=1131 audit(1773245828.936:10): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg=‘unit=dev-xvdc1-swap comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[2026-03-11 12:17:09] [.[0;32m OK .[0m] Finished .[0;1;39mmodprobe@dm_mod.service.[0m - Load Kernel Module dm_mod.
[2026-03-11 12:17:09] [.[0;32m OK .[0m] Finished .[0;1;39mmodprobe@efi_pstore.service.[0m - Load Kernel Module efi_pstore.
[2026-03-11 12:17:09] [.[0;32m OK .[0m] Finished .[0;1;39mmodprobe@loop.service.[0m - Load Kernel Module loop.
[2026-03-11 12:17:09] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-vconsole-setup.service.[0m - Virtual Console Setup.
[2026-03-11 12:17:09] [ 4.058631] intel_rapl_msr: PL4 support detected.
[2026-03-11 12:17:11] [.[0m.[0;31m* .[0m] Job qubes-mount-dirs.service/start running (3s / no limit)
.[K[.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-mount-dirs.service/start running (4s / no limit)
[2026-03-11 12:17:12] [ 7.211876] EXT4-fs (xvdb): mounted filesystem af038240-4c05-4662-b4dc-87bc239de45b r/w with ordered data mode. Quota mode: none.
.[K[.[0;32m OK .[0m] Finished .[0;1;39mqubes-mount-dirs.service.[0m …Initialize and mount /rw and /home.
[2026-03-11 12:17:12] .[K[ 7.277415] kauditd_printk_skb: 7 callbacks suppressed
[2026-03-11 12:17:12] [ 7.277420] audit: type=1130 audit(1773245832.288:18): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg=‘unit=qubes-mount-dirs comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[2026-03-11 12:17:12] Starting .[0;1;39mqubes-relabel-rw.service.[0m - Relabel /rw and /home…
[2026-03-11 12:17:14] [.[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-relabel-rw.service/start running (7s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-relabel-rw.service/start running (7s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-relabel-rw.service/start running (8s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m*.[0m] Job qubes-relabel-rw.service/start running (8s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m] Job qubes-relabel-rw.service/start running (9s / no limit)
.[K[ .[0;31m*.[0m] Job qubes-relabel-rw.service/start running (9s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m] Job qubes-relabel-rw.service/start running (10s / no limit)
[I TRIMMED THIS FOR BREVITY, Forum Character Limit]
.[K[.[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-relabel-rw.service/start running (56s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-relabel-rw.service/start running (56s / no limit)
Can someone please help me parse these logs for the critical info?
Thank you! :heart:
As the AppVM volume is properly mounted, it is unlikely that data corruption and/or loss has occurred, I guess.
The qubes-relabel-rw.service is taking a long time to complete for some reason, and it looks like it’s preventing VM startup.
Increasing the VM’s qrexec_timeout value extends the time before startup failure. After setting it from 60 to 3600 (1 hours) with the following command, start the VM and patiently wait for qubes-relabel-rw.service and VM startup to complete.
$ qvm-prefs private qrexec_timeout 3600
Before taking any actions to the VM, strongly consider taking a backup to protect your data.
I actually just created a backup a few days ago, and only volatile data (e.g., new emails in Thunderbird, and files already synced through Syncthing) has changed.
This worked!! Thank you! I will have to “trim” this AppVM and figure out how to modularize it a bit more (maybe into different VMs), because clearly it shouldn’t take so long to startup.
