Hey folks,
I am using a
- TUXEDO Pulse 14 (AMD Ryzen 7 4800H, Radeon RX Vega, integrated graphics)
- with Qubes-R4.0.4-x86_64
and already found some solutions for several problems.
There are still two things on my list which are maybe connected.
It is not possible to reduce the brightness of the build in monitor. I found a topic for that (not resolved so far):
https://forum.qubes-os.org/t/gpu-driver-necessary-for-functional-backlight-control/3544/
The issue for this topic: After connecting several different external monitor with several suitable cables via HDMI the monitor is not detected.
Using other distros this setup works => hardware is OK.
Output of xrandr -q
[x3@dom0 Documents]$ xrandr
xrandr: Failed to get size of gamma for output default
Screen 0: minimum 1920 x 1080, current 1920 x 1080, maximum 1920 x 1080
default connected 1920x1080+0+0 0mm x 0mm
1920x1080 77.00*
$ lspci -k
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1630
Subsystem: Device 1d05:109f
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Device 1631
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1632
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 1634
Kernel driver in use: pcieport
00:01.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 1634
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1632
00:02.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 1634
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1632
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 1635
00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 1635
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 51)
Kernel driver in use: piix4_smbus
Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1448
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1449
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 144a
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 144b
Kernel driver in use: k10temp
Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 144c
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 144d
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 144e
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 144f
01:00.0 Network controller: Intel Corporation Device 2723 (rev 1a)
Subsystem: Intel Corporation Device 0084
Kernel driver in use: pciback
Kernel modules: iwlwifi
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
Kernel modules: r8169
03:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd Device a808
Subsystem: Samsung Electronics Co Ltd Device a801
Kernel driver in use: nvme
Kernel modules: nvme
04:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Device 1636 (rev c6)
Kernel modules: amdgpu
04:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Device 1637
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
04:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Device 15df
04:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Device 1639
Kernel modules: xhci_pci
04:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Device 1639
04:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] Device 15e2 (rev 01)
Kernel modules: snd_pci_acp3x
04:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Device 15e3
05:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81)
Kernel driver in use: ahci
05:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81)
Also tried to use the xfce system tool “Display” (configure new displays when connected) without success.
Do you have an idea how to get the external monitor working via HDMI?
If you need more information / logs, please let me know.
Thanks in advance!
Xorg.0.log (26.1 KB)
