Remarks
System76 provides detailed instructions for physically removing or replacing certain components, so I:
- Removed the Wi-Fi/Bluetooth module before powering on.
- Disconnected the webcam/microphone connector before powering on.
- Installed extra RAM (2 x 32 GB DDR4 SO-DIMMs @ 3200 MHz).
- Installed an extra NVMe Gen4 SSD.
Qubes OS installation was a breeze.
In addition:
- When I looked at the coreboot settings, I was surprised to see that Intel ME was enabled by default, so I installed coreboot-configurator in Pop!_OS to “disable” it (insofar as it can) with a simple toggle. This change was reflected in the coreboot settings afterward.
- Suspend does not work on Qubes (presumably due to S0ix, but possibly compounded by disabling ME).
- The HDMI 2.1 port doesn’t work with external monitors in Qubes, but it works in Pop!_OS. (Update: works with
kernel-latest-6.0.12-1.) - The DisplayPort (via USB-C) port also doesn’t work with external monitors in Qubes. (Update: probably also works with
kernel-latest-6.0.12-1.) - The MicroSD card reader doesn’t work.
- Although coreboot states that the TPM is active,
qubes-hcl-reportdoes not recognize it. - The easiest way to update the firmware on System76 laptops seems to be via Pop!_OS, where there’s a built-in one-button update tool, so keeping the default SSD with Pop!_OS preinstalled seems useful. Since this laptop has two NVMe slots, I simply moved the default (slower) SSD to the slower Gen3 slot and used the faster Gen4 slot for my Samsung 990 PRO. This way, I won’t have to reopen the case the next time I need to use Pop!_OS to update the laptop’s firmware. Both OSes are independently LUKS-encrypted.
On the positive side, compared to my old ThinkPad T450s, this setup is noticeably faster, runs open-source firmware, and is not vulnerable to QSB-081.
Note: This is the second darp8 HCL report to be posted. The first one is here.
layout:
'hcl'
type:
'laptop'
hvm:
'yes'
iommu:
'yes'
slat:
'yes'
tpm:
'unknown'
remap:
'yes'
brand: |
System76
model: |
Darter Pro
bios: |
2022-11-21_b337ac6
cpu: |
12th Gen Intel(R) Core(TM) i7-1260P
cpu-short: |
i7-1260P
chipset: |
Intel Corporation Device [8086:4621] (rev 02)
chipset-short: |
Alder Lake
gpu: |
Intel Corporation Device [8086:46a6] (rev 0c) (prog-if 00 [VGA controller])
gpu-short: |
Integrated Graphics (Iris Xe)
network: |
Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
memory: |
65380
scsi: |
usb: |
3
versions:
- works:
'yes'
qubes: |
R4.1
xen: |
4.14.5
kernel: |
5.15.52-1
remark: |
<a class='ext-link' href='https://forum.qubes-os.org/t/16466'>read more</a>
credit: |
Andrew David Wong
link: |
https://andrewdavidwong.com/
