layout:
'hcl'
type:
'Notebook'
hvm:
'yes'
iommu:
'yes'
slat:
'yes'
tpm:
'2.0'
remap:
'yes'
brand: |
LENOVO
model: |
83C7
bios: |
KTCN45WW
cpu: |
12th Gen Intel(R) Core(TM) i7-1260P
cpu-short: |
FIXME
chipset: |
Intel Corporation Device [8086:4621] (rev 02)
chipset-short: |
FIXME
gpu: |
Intel Corporation Alder Lake-P GT2 [Iris Xe Graphics] [8086:46a6] (rev 0c) (prog-if 00 [VGA controller])
gpu-short: |
FIXME
network: |
Intel Corporation Alder Lake-P PCH CNVi WiFi [8086:51f0] (rev 01)
memory: |
16109
scsi: |
usb: |
4
certified:
'no'
versions:
- works:
'FIXME:yes|no|partial'
qubes: |
R4.2.4
xen: |
4.17.5
kernel: |
6.6.77-1
remark: |
FIXME
credit: |
FIXAUTHOR
link: |
FIXLINK
Remarks
- Tap to click on the touchpad doesn’t work.
- Keyboard backlight only works when set to always active;
- Only boots with UEFI on Setup Mode;
- Special function keys like Print Screen or Lock Screen don’t work;
- The laptop freezes before GRUB starts unless it’s reset by the Ctrl + Alt + Del keyboard shortcut, in which it initializes GRUB safely;
sys-usbworks as intended, but it doesn’t recognizes the Lenovo EPOS USB headset;- It doesn’t show the ports in the mixed ports USB HUB, though it though it shows the USB HUB itself;
- It recognizes all the USB ports in the mixed ports USB HUB, but it doesn’t uses the Ethernet port despite the USB HUB signaling it’s plugged.
HCL_Lenovo_Yoga_Slim_6_14IAP8.yml (792 Bytes)
