layout:
'hcl'
type:
'Desktop'
hvm:
'yes'
iommu:
'yes'
slat:
'yes'
tpm:
'2.0'
remap:
'yes'
brand: |
LENOVO
model: |
30GS000HUK
bios: |
S0IKT78A
cpu: |
13th Gen Intel(R) Core(TM) i9-13900
cpu-short: |
FIXME
chipset: |
Intel Corporation Raptor Lake-S Host Bridge/DRAM Controller [8086:a700] (rev 01)
chipset-short: |
FIXME
gpu: |
Intel Corporation Raptor Lake-S GT1 [UHD Graphics 770] [8086:a780] (rev 04) (prog-if 00 [VGA controller])
gpu-short: |
FIXME
network: |
Intel Corporation Device [8086:0dc7] (rev 11)
memory: |
32399
scsi: |
WDC WD4003FFBX-6 Rev: 0A83
usb: |
1
certified:
'no'
versions:
- works:
YES
qubes: |
R4.3-rc3
xen: |
4.19.3
kernel: |
6.12.54-1
remark: |
FIXME
credit: |
Frank
link: |
FIXLINK
Remarks
- Mostly working very well and reliably
Before updates there were freezing issues requiring hardware reboot with many VM open, sometimes just before freeze when present and running, graphical content of one window/vm appeared to be in another after system left running unattended e.g. left monitoring network overnight.
Except a number of times if I leave the system running it will have frozen requiring hardware restart. Once Windows 11 VM seemed to have message on a reduced size blank window saying the device had experienced a hardware device failure and to reboot. I initially thought this was an unsurprising issue with the Windows VM, but the whole system was frozen and I had to do a hardware reboot and when I did it couldn’t see the drive and tried to boot on an empty spare drive. I assumed this was a drive failure or corruption, but all booted correctly after re-selecting the correct device in BIOS.
As far as I can see the logs oly record normal activity up to freeze.
For now I will run without Win11
not much of an issue but inconsistently sometimes when booting to the drive unlock gets to the usual unlock screen and sometimes it goes to bare text, which after entering the unlock code the screen clears and three small grey squares appear, but after a while the login screen appears.
Testing use in managing and monitoring local IT systems
- sys-usb (default)
- sys-net (default)
- sys-firewall (default)
- sys-firewall (local subnet connect only)
- Default (debian/fedora) templates for common use
- Extra default templates when third party software used
- vm storage, no network (operations only, assets (assets stored elsewhere)
- vm vault, no network
- vm Backup USB for backups, no network
- dvm default (fedora42)
- dvm debian13
- vm browser monitoring servers (local only firewall)
- vm remote connection local systems (local only firewall)
- vm accessing central services
- vm accessing supplier services
- vm work email and messaging
- Standalone Win 10 with work software, inventory etc (transferred)
- Standalone Win 11 with work software, inventory etc (Replacement)
Wishlist
- remote access to vm browser monitoring servers NOT Dom0 or Qubes generaly
HCL-Lenovo-Thinkstation-P3-MT-30GS.yml (823 Bytes)
