HCL - Laptop - ASUS VivoBook Pro N752VX-GC164T (i7-6700HQ)
layout:
  'hcl'
type:
  'Notebook'
hvm:
  'yes'
iommu:
  'yes'
slat:
  'yes'
tpm:
  '2.0'
remap:
  'yes'
brand: |
  ASUSTeK COMPUTER INC.
model: |
  N752VX
bios: |
  N752VX.303
cpu: |
  Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz
cpu-short: |
  FIXME
chipset: |
  Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Host Bridge/DRAM Registers [8086:1910] (rev 07)
chipset-short: |
  FIXME
gpu: |
  Intel Corporation HD Graphics 530 [8086:191b] (rev 06) (prog-if 00 [VGA controller])
gpu-short: |
  FIXME
network: |
  Intel Corporation Wireless 7265 [8086:095a] (rev 59)
  Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 12)
memory: |
  23991
scsi: |
  SAMSUNG MZNLF128 Rev: 301Q
  DVDRAM GUE1N     Rev: AS00
  CT120BX500SSD1   Rev: R013
usb: |
  2
certified:
  'no'
versions:
  - works:
      'FIXME:yes|no|partial'
    qubes: |
      R4.2.1
    xen: |
      4.17.4
    kernel: |
      6.6.25-1
    remark: |
      FIXME
    credit: |
      FIXAUTHOR
    link: |
      FIXLINK
Remarks
  • Install works by default, except that I get a popup error message which says “Unable to reset PCI device 03:00:1” (Realtek ethernet).
  • Boot fails ~50% of the time (like with Debian and Ubuntu), I suspect that’s an intel-microcode bug.
  • Boot takes a long time, there is a 10 seconds black screen in between grub and luks pwd prompt.
  • The Realtek ethernet is blocking sys-net to start, I added “Realtek PCI smart card device” to sys-net. I don’t know if ethernet works but there is no error message anymore.
  • Intel wireless work fine.
  • Youtube videos are not playing smoothly (maybe 5 or 10 images per second)
  • The laptop internal keyboard is not a USB keyboard.
  • I have only tested very basic stuff, I am not familiar yet with the OS.
HCL - ASUS VivoBook Pro N752VX-GC164T.yml (1.0 KB)
Update with Qubes 4.3.0
This laptop is not anymore compatible with Qubes.
The install runs fine but it will freeze at first boot.
The reason is the following : The laptop is not anymore compatible with the Linux kernel since around version 4.12.xxx. And since Qubes 4.3.0, dom0 is based on “Debian + Linux 4.12”.
For standard Linux distributions it can still boot with the grub “nolapic” option or in safe mode, but that is not relevant to Qubes because “nolapic” deactivates multi-processing, and so the laptop would not satisfy the minimum hardware requirements.
(Side note : With Windows 11, all is running fine, there is no sign of any hardware problem)
Correction of my previous post : I found a way to make the laptop hardware compatible again with recent Linux kernel versions and keeping the multi-cores advantage.
At first boot : Add temporarily the “nolapic” or “dis_ucode_ldr” to grub/systemd linux boot parameters.
Once booted : Either, add “dis_ucode_ldr” to your boot config or either, uninstall the 2 following Debian packages :
“intel-microcode” + “iucode-tool”
  • That works with Debian 13.4, Fedora 44, Ubuntu 26.04.
  • Not tested yet with Qubes 4.3.0
Remark : That will make your processor firmware very very outdated (year 2019 from the bios cpu firmware). Is it a security concern that dom0 is using an outdated CPU firmware ?
That depends on your threat model.
It is strange to have such a regression in the linux kernel.
I know it is a long time now, and maybe you do not care now, but …
Do you see detail during first boot if you delete “quiet” and “rhgb”, but not put “nolapic” ? Or use a verbose boot option?
What happens at the freeze?
Can you tell us what different possibilities you tried for kernel command line?
nolapic is a very big “hammer” for hiding problems, but processor microcode is a strange one.
Let’s say that I have already spent so much time investigating into my bug, that I have now fully accepted to live with a 2019 intel-microcode version, moreover this is a end-of-life/outdated laptop (9 years old).
I have tried a lot of grub options found randomly on internet, but I didn’t took notes of the ones I tried, it is all about : apic, lapic, acpi, gpu, nomodeset, …
  • With Debian 13 default setup, the freeze happens very early in the boot process. After the grub boot selection, it directly freezes with a black screen.
  • With Debian 13 default setup + linux arguments “ro dis_ucode_ldr”, I get a boot freeze
  • With Debian 13 default setup + linux arguments “ro quiet dis_ucode_ldr”, it boots
  • With Debian 13 default setup + linux arguments “ro nosplash debug --verbose”, it freezes with :
Booting a command list
Loading Linux 6.12.85+deb13-amd64 ...
Loading inital ramdisk ...
                 EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
                 EFI stub: Measured initrd data into PCR 9
Stuff I am sure about :
  • I get the same bug whatever I use grub or systemd-boot
  • It freezes before I get the opportunity to input my root “/” luks passphrase, the bug is into an early stage of the boot process
  • The bug is capricious, for example removing the “quiet” option can provoke the freeze.
It is very strange.
The only thing I notice is the EFI “measured” message: it suggests that “Secure boot” is enabled in the EFI/BIOS settings. I think Qubes has not been compatible with this for some time.
Can it be that the CMOS battery is dead, and settings are getting lost? I think that would be obvious, because the clock would always be wrong.
  • I have removed the laptop battery a long time ago (capacity had reached 0kW.h), the computer is now like a desktop computer.
  • Clock is lost only when I unplug the laptop from electric current.
  • Bios settings are all saved even if I unplug the laptop from electric current.
  • I have never used/activated secure boot.
  • When I say Debian, I am NOT talking about dom0 Debian, I am talking about the Debian distrib. Because I was trying first to investigate my problem with a raw Debian distrib.
