HCL - Gigabyte Aorus Ultra Z790I
layout:
  'hcl'
type:
  'Desktop'
hvm:
  'yes'
iommu:
  'yes'
slat:
  'yes'
tpm:
  '2.0'
remap:
  'yes'
brand: |
  Gigabyte Technology Co., Ltd.
model: |
  Z790I AORUS ULTRA
bios: |
  F10
cpu: |
  12th Gen Intel(R) Core(TM) i5-12400
cpu-short: |
  FIXME
chipset: |
  Intel Corporation Device [8086:4650] (rev 05)
chipset-short: |
  FIXME
gpu: |
  Intel Corporation Alder Lake-S GT1 [UHD Graphics 730] [8086:4692] (rev 0c) (prog-if 00 [VGA controller])
gpu-short: |
  FIXME
network: |
  Intel Corporation Device [8086:7a70] (rev 11)
  1692]
  Intel Corporation Ethernet Controller I225-V [8086:15f3] (rev 03)
memory: |
  65300
scsi: |
usb: |
  1
certified:
  'no'
versions:
  - works:
      'FIXME:yes|no|partial'
    qubes: |
      R4.2.4
    xen: |
      4.17.5
    kernel: |
      6.12.47-1
    remark: |
      FIXME
    credit: |
      FIXAUTHOR
    link: |
      FIXLINK
Remarks
Everything works pretty well. I use the BIOS to control the case and CPU fans.
Update - There is no analog audio input or output device listed in the audio mixer. I didn’t notice right away because I’ve been using USB and HDMI for audio. There is some weird built in headphone amp on this board. Maybe that’s why it doesn’t work out of the box.
2nd Update - The analog audio output works fine. It’s just connected on the board as a USB device. So to use the analog 3.5mm headphone output, just use sys-usb to connect ‘Generic USB Audio’ to the VM outputting sound. It may also be necessarry to run pavucontrol in the VM that is outputting audio and select ‘Generic USB Audio’ as the default output device.
Qubes-HCL-Gigabyte_Technology_Co___Ltd_-Z790I_AORUS_ULTRA-20251013-154613.yml (883 Bytes)
