HCL - Framework 13 Intel Core Ultra Series 1
layout:
  'hcl'
type:
  'Notebook'
hvm:
  'yes'
iommu:
  'yes'
slat:
  'yes'
tpm:
  '2.0'
remap:
  'yes'
brand: |
  Framework
model: |
  Laptop 13 (Intel Core Ultra Series 1)
bios: |
  03.01
cpu: |
  Intel(R) Core(TM) Ultra 5 125H
cpu-short: |
  FIXME
chipset: |
  Intel Corporation Device [8086:7d14] (rev 04)
chipset-short: |
  FIXME
gpu: |
  Intel Corporation Meteor Lake-P [Intel Arc Graphics] [8086:7d55] (rev 08) (prog-if 00 [VGA controller])
gpu-short: |
  FIXME
network: |
  Intel Corporation Wi-Fi 6 AX210/AX211/AX411 160MHz [8086:2725] (rev 1a)
memory: |
  32221
scsi: |
usb: |
  4
certified:
  'no'
versions:
  - works:
      'FIXME:yes|no|partial'
    qubes: |
      R4.2.3
    xen: |
      4.17.4
    kernel: |
      6.10.10-1
    remark: |
      FIXME
    credit: |
      FIXAUTHOR
    link: |
      FIXLINK
Remarks
Everything works as expected, including sleep, WiFi, Bluetooth, microphone, and built-in speakers.
The only things that don’t work are the keyboard media controls / screen brightness controls.
Have not tested the built-in fingerprint reader.
Needed to use kernel-latest to get past an issue with a freeze during boot (after the disk encryption PW prompt but before the Qubes login screen).
That’s interesting that your screen brightness controls don’t work. On my Laptop 13 Intel i7 they worked out of the box, and they also work on my AMD Laptop 16.
What kernel version are you running this on?
I got the same laptop as you, but I’m getting that “freeze” at boot.
It’s actually an issue with the X server not detecting any screens.
EDIT: I’m dumb, I just read the kernel version in the report (6.10.10)
