HCL - Framework 13 (2025 - Ryzen AI 300)
layout:
  'hcl'
type:
  'Notebook'
hvm:
  'yes'
iommu:
  'yes'
slat:
  'yes'
tpm:
  '2.0'
remap:
  'yes'
brand: |
  Framework
model: |
  Laptop 13 (AMD Ryzen AI 300 Series)
bios: |
  03.03
cpu: |
  AMD Ryzen AI 9 HX 370 w/ Radeon 890M
cpu-short: |
chipset: |
  Advanced Micro Devices, Inc. [AMD] Device [1022:1507]
chipset-short: |
  FIXME
gpu: |
  Advanced Micro Devices, Inc. [AMD/ATI] Device [1002:150e] (rev c1)
gpu-short: |
  Radeon 890M
network: |
  MEDIATEK Corp. Device [14c3:0717]
memory: |
  130345
scsi: |
usb: |
  6
certified:
  'no'
versions:
  - works:
      'yes'
    qubes: |
      R4.2.4
    xen: |
      4.17.5
    kernel: |
      6.14.4-1
    remark: |
      with kernel-latest
    credit: |
      ole
    link: |
      FIXLINK
Remarks
used for over a month now, daily driver,
needs kernel-latest for R4.2.4,
disable secure boot in bios.
wifi works,
sleep works,
webcam (internal as USB), LAN port (seen as USB) work,
keyboard+trackpad (internal direct / not usb) work,
Fingerprint reader, Bluetooth (internal as USB) - not tested
bug: sometimes when attaching a new external monitor with different HiDPI scaling parameters the DE restarts (crashes), with new login (all running qubes/programs are unaffected) and after new login it works flawlessly. It looks more like a software bug of not handling screen buffer sizes/locations correctly.
Qubes-HCL-Framework-Laptop_13__AMD_Ryzen_AI_300_Series_-20250714-161514.yml (776 Bytes)
I have the Framework 13 with Ryzen AI 9 HX 370 w/ Radeon 890M. I’m having an issue on any kernel after 6.15 where I get a black screen instead of the disk encryption password prompt (i.e. kernel 6.16 and 6.17 at the time of writing do not boot). This is similar to what is described here: Framework Laptop 16 (AMD Ryzen 7040 Series) - #6 by pubesos
Workaround has been to interrupt GRUB during boot and select the Qubes option with the 6.15 kernel and occasionally test the later kernels as they get updated.
