qubes-hcl-report
layout:
'hcl'
type:
'Convertible'
hvm:
'yes'
iommu:
'yes'
slat:
'yes'
tpm:
'2.0'
remap:
'yes'
brand: |
Dell Inc.
model: |
XPS 13 9310 2-in-1
bios: |
2.32.0
cpu: |
11th Gen Intel(R) Core(TM) i7-1165G7 @ 2.80GHz
cpu-short: |
FIXME
chipset: |
Intel Corporation Tiger Lake-UP3/H35 4 cores Host Bridge/DRAM Registers [8086:9a14] (rev 01)
chipset-short: |
FIXME
gpu: |
Intel Corporation TigerLake-LP GT2 [Iris Xe Graphics] [8086:9a49] (rev 01) (prog-if 00 [VGA controller])
gpu-short: |
FIXME
network: |
Intel Corporation Wi-Fi 6 AX201 [8086:a0f0] (rev 20)
1651]
memory: |
16090
scsi: |
usb: |
4
certified:
'no'
versions:
- works:
'FIXME:yes|no|partial'
qubes: |
R4.3-rc1
xen: |
4.19.3
kernel: |
6.15.10-1
remark: |
FIXME
credit: |
FIXAUTHOR
link: |
FIXLINK
hostnamectl
Laptop: Dell XPS 13 9310 2-in-1
Operating System: Qubes OS 4.3-rc1 (R4.3)
Kernel: Linux 6.15.10-1.qubes.fc41.x86_64
dmidecode -t memory
Memory: 16 GB
Memory Speed: 4267 Mhz
Memory Type: LPDDR4
notes
- had to add some iommu, i915 and other kernel options to get installer to even load/boot - cannot find specifics on readthedocs - I think it was mentioned in the actual installer READMEs.
- had to disable intel software raid in bios for it to detect nvme disks
- had to add āoptions snd_hda_intel power_save=0 power_save_controller=Nā to /etc/modprobe.d/snd_hda_intel.conf
- had to mess around with xsetwacom --set to ācalibrateā the touchscreen as I have 2nd monitor (Samsung S34J550WQE) attached via DP
- fingerprint reader seemed recognized but have not tested it yet.
- Performance is āOKā:
- Run about 7 qubes, including dom0 and 3x sys-* and 1x vpn - so can handle around 2-3 additional active ābig templateā qubes (depending on workloads), minimal templates/lite qubes/alpine qubes are a WIP but should further improve performance.
- Video performance is unstable - when it works it works great, but when it does not it becomes sluggish. Still troubleshooting as it was working fine but I think a recent 4.3rc1 kernel/dom0 update or grub/uefi/x11 config clobber changed something (maybe the āintel driverā as it now uses modesetting) and as such recently video playback on the second monitor has become unusable - 13" laptop monitor works fine however.
HCL-Dell-XPS-9310-2-in-1.yml (863 Bytes)
