The first time, the installation stopped at “Reached target Paths”. I had to deactivate VMD, but couldn’t see in it BIOS. It’s a ‘hidden’ parameter in the BIOS : Ctrl + S to see it in the advanced and deactivate it.
Then, everything went smoothly.
Using a USB/VGA hub to plug a second monitor, mouse and keyboard :
- Monitor OK
- Mouse OK (ask if I want to authorize it, then ok)
- Keyboard : the doc is not updated yet (I plan to do it)
– For Qubes 4.2, the keyboard policies are now in /etc/qubes/policy.d directory in the 50-config-input.policy by default.
I edited the rules directly from Qubes Global Config (Qubes Managers > System > Global Config and in the USB Devices tab).
Everything ok so far, but I think I had an issue with a restart (will check and update if needed).
HCL_Nitro ANV15-51.yml (1.1 KB)
