Hello Everyone,
I’ve tried to install Qubes now several times, but I think I have always installed a manipulated version unfortunately. I tried to download the ISO from several different PCs, but I noticed on all PCs strange behaviors, so I am guessing there is something wrong with my installation. Anyways I tried to install one version I got recently,
where I had some trust in it.
However, I noticed quite some things:
- After choosing the verify installation medium and install screen, I got the following log messages:
- Unknown device “/dev//run/install/repo//images/install.img”: no such device
- Unknown device “/sys/”: No such device
- During installation the installation of the templates took about 35 minutes for debian and whonix, which seems quite much, as I have an up to date Laptop in the middle to upper price range
- when booting, a message appears, that says something like “…dom0 unrestricted…”
- At the first boot into the system there are several errors and audits inside the logs, see attached pastebins
- The first update for the debian template failed, with the message that it failed to connect to the repos
- The other templates had this message as well, but suddenly they could download packages
Here is the dom0 log: System.log - Pastebin.com
And here is the log from the Update: Updating debian-12-xfceRefreshing package infoRefreshing packages.Fail to - Pastebin.com
As I am new to Qubes I do not know, what should be a normal log output after a successfull installation. Therefor I am posting here, to get some insight, if this is normal and I am going crazy, or if my suspicion is right. Thanks in advance for your help and all the best!
Kind Regards,
VerifyingQubesInstal
