Has anyone succeed running yggdrasil in netvm?
I’ve started yggdrasil normally. It shows details with these commands:
yggdrasilctl -v getSelf
yggdrasilctl -v getPeers
But ping doesn’t succeed for my yggdrasil addresses on other my mashines. I can ping ubuntu from fedora & back but can’t ping them from Qubes OS netvm qube.
Has Qubes any specific settings required for yggdrasil to work?
Late answer but I was kicked out from this forum.
I have a GUIX yggdrasil in sys-net for i2pd. You can have a GUIX overlay or GUIX debian/rpm created package install with GUIX see guix-pack which will be on the safe side. I did not forward tini-proxy yet because it might interfere with the clock. What I strongly suggest is NOT to use the Debian/Amazon repo. It is hosted on one of the intelligence clouds.
2023/05/18 05:03:19 Starting up…
2023/05/18 05:03:19 Startup complete
2023/05/18 05:03:19 Starting multicast module
2023/05/18 05:03:19 UNIX admin socket listening on /var/run/yggdrasil.sock
2023/05/18 05:03:19 Interface name: tun0
2023/05/18 05:03:19 Interface IPv6: 203:363b:f349:9dd0:933e:588a:f156:35a4/7
2023/05/18 05:03:19 Interface MTU: 53049
2023/05/18 05:03:19 Your public key is 1c9c40cb6622f6cc1a7750ea9ca5b38231d49b4dc507ecae622408ddf2086111
2023/05/18 05:03:19 Your IPv6 address is 203:363b:f349:9dd0:933e:588a:f156:35a4
2023/05/18 05:03:19 Your IPv6 subnet is 303:363b:f349:9dd0::/64
2023/05/18 05:03:19 Listening for TLS on: [fe80::86b3:b19f:eba1:f720%ens6]:41065
2023/05/18 05:03:19 Listening for TLS on: [fe80::fcff:ffff:feff:ffff%vif6.0]:33119
I suggest you to use yggstack instead and forward remote services from yggdrasil to your qubes
