i get a MCE with heads and the T430 when running 3740 CPU. I will check if its the same MCE as yours. I have a 2nd t430 and a 2nd 3740 CPU here so if they both do it with the exact same error, its likely something to do with Coreboot
normally a MCE is down to damage to the CPU (previous heat damage etc) but it would be weird if three different T430s with three different CPUs had the exact same MCE
That would confirm my suspicions. Initial online research shows that
this is a somewhat common error folks see when switching to Linux. They
also all report their CPU working just fine.
It might have to do with the CONFIG_INTEL_PMC_CORE kernel parameter
and/or the OPTIONAL_TABLE stuff in Heads.
