Hardware Compatibility List and Wifi
More progress. I can create new Qubes Application templates and delete them as well.
Next step - fix the network.
I’ve looked at the Hardware Compatibility List. (My computer runs Qubes perfectly, but isn’t on the list, so I will submit my computer details). There is no section for Wifi adaptors.
Two questions please:
Q1. Should there be a section for Wifi adaptors? Would this help?
Q2. How do I select a Wifi adaptor for use with Qubes OS?
You can search the forum for your desired WiFi adapter model or chipset to see if it was reported in the HCL before or someone confirmed that it works.
