This guide is obsolete, doesn’t help, and will reduce the security of your QubesOS machine overall. Do not follow this guide. I have kept it up for archiving purposes.
COMPLETE OVERHAUL SINCE 9/12/2024!
this guide works no matter whether or not you chose disposable sys-net or not. no nonsense guide, if you chose Debian as a base, simply substitute for the proper commands on Debian. lets start.
SECTION 1
open a dom0 terminal and install a fedora minimal template. do not close the terminal yet.
from the docs on minimal templates, ‘If your network devices need extra packages for the template to work as a network VM, use the lspci command to identify the devices, then run dnf search firmware (replace firmware with the appropriate device identifier) to find the needed packages and then install them.’
update packages
dnf update && dnf upgrade
THE HARDENING (UNTESTED! I CANNOT TEST THIS, SINCE AS OF 2025/10/18 I DO NOT RUN QUBES!) lets start with /etc/sysctl.d and /etc/modprobe.d by copy-pasting the relevant secureblue files from their GitHub.
I am allergic to nftables and cannot understand it. the ideal solution here is to use the Qubes default nftables rules but in this guide we will use ufw because of my lack of know-how. dnf install ufw && ufw enable && systemctl enable --now ufw
regenerate initramfs because we edited modprobe.
dracut --regenerate-all --force
exit the XTerm and shutdown net-dvm, make a clone of default-dvm named network-dvm and change the template of network-dvm to net-dvm.
shutdown sys-net and change the template from default-dvm to network-dvm.
Sorry for any inaccuracies, error, lack of sources, unclear instructions, etc. I don’t use Qubes anymore as of 2025/10/18 and cannot overhaul the guide completely until I install Qubes on my free drive.
yes, since sys-net is your weakest link, as in, if it gets hacked, youre fucked. and its quite easy to hack aswell, this makes it more difficult to hack into sys-net, and even if an attacker did get in, this limits what they can do to cause significant damage.
by default, sys-net is based off Fedora-38-Xfce, and not Fedora-38-Minimal, and obviously this is not as good, since minimal would have less attack vectors since its, well, minimal. by default, passwordless-root is also enabled in sys-net, and there isnt a firewall inside of sys-net to prevent attackers from breaking in, with the large attack surface of the default. the minimal templates have a much lesser attack surface, they do not have passwordless root, and if following my guide, will have a firewall, which wont do much since there arent really attack vectors to abuse with the minimal VMs, but its always good to go above and beyond in terms of securing the highest-risk qube. as for sys-firewall, what ive described is only really needed if youre being hunted by the CIA or KGB or something.
to your first statement, if youre referring to sys-firewall, it does not apply to sys-net. if you arent, im unaware of what youre referring to and would appreciate some elaboration. as for your second statement, im gonna have to also ask you to elaborate, since sys-net is indeed the one running network services, which is kind of why i made the guide.
I see, i was unaware of that and will update the guide to remove the firewall part. as for your second statement, according to Qubes docs minimal templates, none. the point im making is that since sys-net is the only qube actually communicating with the ethernet controller (or router if youre on wifi) then its the only qube that an attacker could directly attack, minimizing the attack surface prevents the ways in which an attacker could go about penetrating into sys-net, and we’ve seen examples a few years ago with a user who was being targeted by israeli hackers, having his sys-net being infiltrated as we see here Forensics on sys-net (take his statements with a grain of salt though because some of what he says doesnt make sense)
actually might not remove it, since ufw offers easy to use customizability that would be more beneficial to most users than nftables. especially if you need to set specific rules and configs and arent willing to spend a few hours tweaking. also considering the fact that youd have to config it to be like the previous defaults, which im assuming most people here dont know how to do.
I’m not sure ufw is more customizable than nftables. But yeah, that could be useful for people allergic to nftables which is way more complicated than ufw.
for sure nftables is more customizable, but i dont like scrolling through a ton of code to change 1 setting, and i dont think the increase in customizability is enough for an advanced user ti want to choose it, over ufw. as when youre trying to setup a good firewall config, you dont want to spend 6 days, but instead just 6 minutes.
