Introduction
I have some applications, that run in the browser but I don’t want Firefox to remember all my passwords and history.
Some apps are in external repositories and installing them in Qubes OS needs special workaround but browser bars fills important space…
Here’s the solution, you’ll tweak Firefox to looks like normal app ![]()
Requirements
So, let’s say, you have separated appVM where is firefox, and you set you homepage to site which’ll become your webapp.
Method 1 - Addons
(Easiest, may not work for some sites)
go to addons.mozilla.org and install Popup window and Web App mode
Go to options ==> Extensions ==> Web App Mode settings ==> add your homepage site with wildcard to sites that will automatically start in this mode.
Test if it works by reopening Firefox (there is no need to restart appVM)
Note:
If something crashes, then while firefox starts, quickly type CTRL+T to open new tab which will stay in default mode, where you have options
Method 2 - Firefox SSB
Read about this method here
Method 3 - Firefox Profiles
I tested only the first method but feel free to discuss about every you know/tested on Qubes ![]()
