Hi, I have a surprising issue on a desktop where I just installed Qubes. I was manually adding a sys-usb qube, and wanted to add the rd.qubes.hide_all_usb parameter to GRUB_CMDLINE_LINUX as part of that process.
It turns out that grub… isn’t installed? There is no /etc/default/grub, /etc/grub.d/, grub2-mkconfig etc. I checked /boot and it doesn’t seem like another bootloader is installed either. There’s just the following
/boot/
efi/EFI/qubes
grub/splash.xpm.gz
grub2/themes/system/
some .png, README, COPYING, theme.txt, unicode.pf2, DejaVuSans
initramfs-5.4....img
symvers-5.4.....qubes.x86_64.gz
System.map-5.4....qubes.x86_64
vmlinuz-5.4.....qubes.x86_64
xen-4.8.5-35.fc25.config
xen-4.8.5-35.fc25.gz
xen-4.8.gz
Of course I don’t see any grub windows when I boot. My bios finds the qubes EFI file and that brings me to the normal qubes setup where I enter the luks password. I guess that’s fine, though surprising that grub wasn’t installed when I did a normal install with default options. If that doesn’t seem like a problem, my question then is just how can I do what would be done with adding rd.qubes.hide_all_usb to /etc/default/grub as described in USB qubes | Qubes OS ?
Thank you
