I failed to create a passthrough GPU VM on my Dell computer. It has 2 cards : one VGA Intel TigerLake-H GT1 and one NVIDIA GeForce RTX 3600 Mobile.
I work with this tutorial : Qubes OS article
For now, dom0 uses RTX 3600 so I try to use Intel VGA card to dedicated VM, but I will change later.
When I launch the VM, I have this error :
libxl_domain_device_construc_rdm : RDM conflict at 0x70000000 and
libxl__build_hvm : checking reserved device memory failed.
Is someone know how to solve this problem or how I can discover why there is a memory error ?
Regards,
Sebastien133.
Change to Optimus in BIOS and passsthrough NVIDIA to HVM.
Thanks a lot for your answer. It seems to work correctly now.
I have to understand now how to parameter Xorg. In the tutorial, I have to connect the device with GUI and after I have to write :
qvm-pci attach gpu_gaming_archlinux dom0:0a_00.0 -o permissive=True -o no-strict-reset=True
It do not the same thing ? I don’t understand why but it seems it’s identical.
Regards,
Sébastien133.
You can’t set permissive option with GUI so you’ll have to use qvm-pci for this if this option is required in your case.
You are welcome. Please mark the answer as solution for the sake of others in the same situation.
