GPD WIN Max 2021
layout:
  'hcl'
type:
  'desktop'
hvm:
  'yes'
iommu:
  'yes'
slat:
  'yes'
tpm:
  'unknown'
remap:
  'yes'
brand: |
  GPD
model: |
  G1619-02
bios: |
  E.GA608..002
cpu: |
  AMD Ryzen 7 4800U with Radeon Graphics
cpu-short: |
  FIXME
chipset: |
  Advanced Micro Devices, Inc. [AMD] Renoir Root Complex [1022:1630]
chipset-short: |
  FIXME
gpu: |
  Advanced Micro Devices, Inc. [AMD/ATI] Renoir [1002:1636] (rev c1) (prog-if 00 [VGA controller])
gpu-short: |
  FIXME
network: |
  Intel Corporation Ethernet Controller I225-V (rev 03)
  Intel Corporation Wireless 7265 (rev 59)
memory: |
  14274
scsi: |
  TOSHIBA USB DRV  Rev: PMAP
usb: |
  2
versions:
- works:
    'FIXME:yes|no|partial'
  qubes: |
    R4.1
  xen: |
    4.14.3
  kernel: |
    5.14.15-1
  remark: |
    FIXME
  credit: |
    FIXAUTHOR
  link: |
    FIXLINK
Remarks
  • Runs the latest 4.1 release release candidate perfectly. No modifications needed to be made to the default install
  • The touchscreen and display’s default orientation is sideways to the position of the keyboard (I have a feeling the screen is identical to an iPad Mini display, and they’ve just repurposed it), so the GRUB menu, Plymouth boot screen, and login screen are all sideways. I have fixed it with an XFCE login script (attached below), but I’m still working on rotating GRUB and Plymouth.
  • Qubes OS with a touchscreen is a lot more awesome that you might think! (I’m going to look for an x86 tablet now…)
  • The built-in keyboard and trackpad, 2x USB A ports, 2xUSB-C ports are each on their own separate USB bus, which is nice. The built-in Xbox 360 controller, however, is with the 2 USB-A ports (which doubles as a pointer device). A sys-usb qube is definitely possible.
  • The internal keyboard (like most laptop keyboards) has things like volume, screen brightness, keyboard backlight control, etc. Fn + F1 acts as volume mute toggle. HOWEVER, when pressed, it makes Qubes OS mute and unmute the volume rapidly for about 2-3 seconds, and then kills the keyboard input (you can click on VM windows, but you cannot type in them, nor can you interact with anything in XFCE). It’s baked into the keyboard’s firmware, so you just have to make sure you don’t press Fn + F1. XFCE muting works without any issue (by clicking on it), just not Fn + F1.
Bash script to fix GPD Win Max display on login (will do nothing on boot, as X11 isn’t running yet…)
#!/bin/sh
#Rotate display 90 degrees right with 1280x800 resolution
xrandr --newmode "800x1280_60.06" 68.500 800 816 832 880 1280 1283 1285 1296 -HSync -VSync
xrandr --addmode eDP1 "800x1280_60.06"
xrandr --output eDP1 --mode "800x1280_60.06" --rotate right
#Rotate touchscreen 90 degress right
xinput set-prop "Intel HID 5 button array" --type=float 177 0 1 0 -1 0 1 0 0 1
xinput set-prop "pointer:Goodix Capacitive TouchScreen" --type=float 177 0 1 0 -1 0 1 0 0 1
xinput set-prop "Virtual core pointer" --type=float 177 0 1 0 -1 0 1 0 0 1
#Map touchscreen to internal display only
xinput map-to-output "Intel HID 5 button array" eDP1
xinput map-to-output "pointer:Goodix Capacitive TouchScreen" eDP1
xinput map-to-output "Virtual core pointer" eDP1
I’m working on a udev rule to make this script run whenever a display is added/removed, otherwise the touchscreen is mapped to all displays combined.
More to be filled in later…
Thank you @alzer89 for this HCL report, which is now online.
I can happily confirm that it looks like S3 suspend/sleep will work flawlessly and as expected with Qubes OS 4.2 on this machine, due to a more recent version of Xen and Xorg being used that can interact better with AMD GPUs in virtual environments.
So that’s definitely something to look forward to in the upcoming release of Qubes OS :blush:
Did you maybe already test the recent RC version on this device?
Of course. It seems to work fine. It’s wonderful having the option to sleep a laptop.
Yes, you can get used to shutting down and booting up between sessions, but you don’t actually realise you miss until you lose it and then get it back :stuck_out_tongue:
