I followed the guide Android-x86 install guide for 4.1 and managed to install Android in Qubes. Hovewer it has google services preinstalled. Is it possible and what is the easiest way to install Android without google services?
Alternatively maybe there is a way to remove google services from that image, either via adb or other way.
There is one project that aims to make software running on android phones “free as in freedom”. Check out: https://www.replicant.us/
Not sure how this would work with what you are trying to do.
Thanks, for the hint. I looked into it and it looks like it’s regular Android image, not iso like from the guide above. Do you know how to turn it into bootable iso for Qubes?
No clue, maybe someone else can chime in.
