Gitian Build Process
Hi
Does Qubes use a Gitian build process for building binaries from source? gitian.org
Gitian uses a deterministic build process to allow multiple builders to create identical binaries. This allows multiple parties to sign the resulting binaries, guaranteeing that the binaries and tool chain were not tampered with and that the same source was used. It removes the build and distribution process as a single point of failure.
You might find these links interesting:
Hi
It might be possible to incorporate IPFS.
See
the download files could be served from an https domain but also an ipfs domain
