Issue #8598 - Qubes Manager crtical error when updating initial memory of appVM
On Oct 12, 2023 - @kenosen writes:
4.2.0-rc3
Changing initial memory in fedora-38 AppVM throws an error.
Attempt t change initial memory in qubes settings of an appVM
Whoops. A critical error has occurred. This is most likely a bug in Qubes Manager.
TypeError: disconnect() failed between 'currentIndexChanged' and all its connections
at line 295
of file /usr/lib/python3.11/site-packages/qubesmanager/settings.py.
line: self.netVM.currentIndexChanged.disconnect()
func: apply
line no.: 295
file: /usr/lib/python3.11/site-packages/qubesmanager/settings.py
Analysis and Diagnosis
It is necessary to double ckeck if the issue still exists. It might be fixed by now. It is also necessary to confirm if changing the initial memory for template itself raises the error. Or changing the initial memory for an AppVM based on the mentioned template.
We are dealing with settings.py of qubes-mager here.
