Getting stuck on Emergency-Backup-Recovery
I’m trying to recover data from a Qubes Backup without the Qubes Restore function, i.e. I want to get into my backup information as if I were using a Linux machine, without Qubes.
I’m following the instructions on Emergency Backup Recovery, but I am stuck on step 1, the part where it says:
Now that you have the decrypted qubes.xml.000 file, search for the backup-path property inside of it. With the backup-path, extract only the files necessary for your VM (vmX).
[user@restore ~]$ tar -i -xvf qubes-backup-2015-06-05T123456 \
    backup-header backup-header.hmac vmX/
For me, I get an error (my target VM is called realestate):
user@restore-play:~$ tar -i -xvf qubes-backup-2023-05-10T164002 \ backup-header backup-header.hmac realestate/
backup-header.hmac
tar:  backup-header: Not found in archive
tar: realestate: Not found in archive
tar: Exiting with failure status due to previous errors
I don’t understand
  • if the instructions say "search for the backup-path property " in qubes.xml.000, why do the terminal instructions not mention either backup-path or qubes.xml.000?
  • why doesn’t tar find backup-header? I am sure I am typing things correctly and previous steps worked okay - its already extracted a file name backup-header to the host directory in an earlier step.
  • why can’t tar find realestate? I know its in the archive!
  • (admission: I don’t understand all of the terminal commands, e.g. what does \ and / do here?)
Help gratefully received.
The \ character is only meant to be entered if the command is typed in as-is broken over two lines, in which case it bridges the two lines. If you’re typing in one line instead, omit that \ so as not to make the shell pass the subsequent space character to tar (which causes it to look for a file named <SPACE>backup-header).
And instead of the actual VM name like realestate there’s an anonymized vmN form that must be used, where N is some number like 123 which can be looked up in qubes.xml.
It’s a bit of a mess… There’s an ongoing effort by @adw and me to rewrite the instructions, maybe take a look at the bleeding edge version.
thanks for this. I’ll work through the “bleeding edge” version today.
Suggestion for instructions @rustybird : instruct us at the start to install xmlstarlet, (along with telling us to install scrypt).
@rustybird Some notes offered here as feedback on the instructions you’re working on.
  • (as above) Include instructions to install xmlstarlet in same section as installing scrypt. Its not really an optional app, so deal with it first.
  • Step 2, [user@restore ~]$ read -r backup_pass
    Add: “Enter your passphrase at the prompt, then hit enter.”
  • Step 9, I don’t think the following line is very useful:
[user@restore ~]$ cat /mnt/img/home/user/your_data.txt
Arguably, its far more useful to the general user to showcase the image contents, so instead use:
[user@restore ~]$ ls /mnt/img/home/user/
Other than that, the instructions you have there are very useable and very important. Can you publish them to the Qubes website soon?
Regards Step 2, That might better be
“Enter your passphrase at the prompt, (n.b. it will be in clear text), then hit enter.”
