If you would like to use a stable, predictable, manageable and reproducible distribution in your AppVMs, you can install the Gentoo template, provided by Qubes in ready to use binary package. For the minimal and Xfce versions, please see the Minimal TemplateVMs and Xfce TemplateVMs pages.
Installation
The standard Gentoo TemplateVM can be installed with the following command in dom0:
To switch, reinstall and uninstall a Gentoo TemplateVM that is already installed in your system, see How to switch, reinstall and uninstall.
After Installing
After a fresh install, we recommend to Update the TemplateVM. We highlight that the template memory/CPU allocation certainly need to be adjusted in some cases. As Gentoo is a linux source distribution, the template needs resources to perform updates or installing any packages. By default, each TemplateVM has 2 VCPUs for 4000 MB Max memory allocated. If needed, double those values, 4 VCPUs for 8000 MB Max memory. For example, it has been observed failing updates or builds with 4 VCPUs for 4000 MB Max memory due to out of memory issue. For more general considerations, we refer to the official Gentoo Handbook.
Hello,
i’m also interested in a working gentoo template for 4.3.
But it would also be fine if we can build it without problems via the qubes-builder but this is also failing because of build problems with qubes packages ;-(.
I thought it would be planned to include the template in the automatic build/test process, which I would very much welcome:
Thanks for all your work on this and qubes at all.
