Hello,
What is the default password for the gentoo-minimal template?
I tried launching passwordless root according to the instructions, but it failed.
Is there a password for the gentoo-minimal template?
Hello,
The package doesn’t seem to be available for gentoo.
Open a root shell from dom0:
qvm-run -u root gentoo-minimal xterm
Change password for root with passwd and user with passwd user
If you want to give sudo access to user without password, add this under “root” in /etc/sudoers
user ALL=(ALL:ALL) NOPASSWD: ALL
