Abstract
GarlicGrater its simple proxy for i2p SAM bridge what provides isolation between pseudonyms and real identity, works like onion-grater
For more information see my guide about i2p in qubes link
How to works
Gralicgrater proxified all commands from user to i2p router and replaces *.length in SESSION CREATE to user provided values, and adds prefix to session IDs
Updates
2026-08-13
Now garlicgrater remove sockets if client crashes, fixed = symbol parsing bug
Code
TCP proxy credits
Source - https://stackoverflow.com/a/78557776
Posted by Estelle Poulin
Retrieved 2026-08-12, License - CC BY-SA 4.0
import socket
import selectors
FORCE_INBOUND_LENGTH = 3
FORCE_OUTBOUND_LENGTH = 3
ID_PREFIX = 'isolated_' # Change this prefix per pseudonym
REAL_SAM_IP = '127.0.0.1'
REAL_SAM_PORT = 7656
FILTERED_SAM_LISTEN_IP = '127.0.0.1'
FILTERED_SAM_LISTEN_PORT = 7657
class TCPProxy:
def __init__(
self,
listen_addr: str,
listen_port: int,
destination_addr: str,
destination_port: int,
self.listen_addr = listen_addr
self.listen_port = listen_port
self.destination_addr = destination_addr
self.destination_port = destination_port
self.selector = selectors.DefaultSelector()
self.connections = {}
@staticmethod
def __sam_parse(sam_command):
sam_command_splited = sam_command.split()
command = f'{sam_command_splited.pop(0)} {sam_command_splited.pop(0)}'
args = {}
for arg_value in sam_command_splited:
args[arg_value.split('=', 1)[0]] = arg_value.split('=', 1)[1]
return (command, args)
@staticmethod
def __generate_sam_command(sam_command: tuple):
command = sam_command[0]
for arg, value in sam_command[1].items():
command += f' {arg}={value}'
command += '\n'
return command.encode('utf-8')
@staticmethod
def __is_sam(sam_command):
try:
if sam_command.decode('utf-8').split()[0] in ['HELLO', 'NAMING', 'STREAM', 'SESSION']:
return True
return False
except:
return False
def __process_sam_command(self, sam_command):
parsed_sam_command = self.__sam_parse(sam_command.decode())
if parsed_sam_command[0] == 'SESSION CREATE':
parsed_sam_command[1]['inbound.length'] = FORCE_INBOUND_LENGTH
parsed_sam_command[1]['outbound.length'] = FORCE_OUTBOUND_LENGTH
if parsed_sam_command[1].get('ID') is not None:
parsed_sam_command[1]['ID'] = f"""{ID_PREFIX}{parsed_sam_command[1]['ID']}"""
return self.__generate_sam_command(parsed_sam_command)
def on_accept(self, sock: socket.socket):
conn, addr = sock.accept()
# For each client connection we create a new server connection
# as well. This lets us support multiple clients and not get the
# data mixed up.
send_sock = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
send_sock.connect((self.destination_addr, self.destination_port))
send_sock.setblocking(False)
self.connections[conn] = send_sock
# Start listening on the client -> proxy and the proxy -> server
# sockets.
self.selector.register(send_sock, selectors.EVENT_READ, self.on_data_from_client)
self.selector.register(conn, selectors.EVENT_READ, self.on_data_from_server)
def on_data_from_server(self, conn: socket.socket):
try:
data = conn.recv(1024)
out_sock = self.connections[conn]
if self.__is_sam(data):
out_sock.send(self.__process_sam_command(data))
else:
out_sock.send(data)
except:
# Client has been killed, forcelly removing sockets
self.selector.unregister(conn)
self.selector.unregister(out_sock)
out_sock.close()
conn.close()
del self.connections[conn]
def on_data_from_client(self, conn: socket.socket):
try:
# This is just a reverse lookup on the connections dict.
return_sock = next(x for x, y in self.connections.items() if y is conn)
return_sock.send(data)
except:
self.selector.unregister(return_sock)
conn.close()
return_sock.close()
del self.connections[return_sock]
def start(self):
# Create a socket for the proxy and have it listen on the address/port you set.
self.proxy_sock = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
self.proxy_sock.bind((self.listen_addr, self.listen_port))
self.proxy_sock.setblocking(False)
self.proxy_sock.listen()
# Start listening for incoming data on the socket.
self.selector.register(self.proxy_sock, selectors.EVENT_READ, self.on_accept)
while True:
# Wait until one of the sockets has data.
events = self.selector.select()
for key, _ in events:
# Call the on_* method associated with it.
callback = key.data
callback(key.fileobj)
proxy = TCPProxy(FILTERED_SAM_LISTEN_IP, FILTERED_SAM_LISTEN_PORT, REAL_SAM_IP, REAL_SAM_PORT)
proxy.start()
