Hi @unman, qubes.i3sec.org is unreachable and (straight) dom0 updates are failing, see below.
[user@dom0 ~]$ sudo qubes-dom0-update --releasever=4.2
Using sys-whonix as UpdateVM for Dom0
Downloading updates. This may take a while...
Unable to detect release version (use '--releasever' to specify release version)
3isec Qubes Dom0 Repository (updates) 0.0 B/s | 0 B 00:41
Errors during downloading metadata for repository '3isec-dom0-current':
- Curl error (7): Couldn't connect to server for https://qubes.3isec.org/rpm/r4.2/current/dom0/fc37/repodata/repomd.xml [Failed to connect to qubes.3isec.org port 443 after 223 ms: Couldn't connect to server]
- Curl error (7): Couldn't connect to server for https://qubes.3isec.org/rpm/r4.2/current/dom0/fc37/repodata/repomd.xml [Failed to connect to qubes.3isec.org port 443 after 0 ms: Couldn't connect to server]
Error: Failed to download metadata for repo '3isec-dom0-current': Cannot download repomd.xml: Cannot download repodata/repomd.xml: All mirrors were tried
The workaround is to disable/skip the repo by using command-line arguments or simply changing “enable = 0” in /etc/yum.repos.d/3isec-dom0.repo
EDIT: correct domain is 3isec.org, not “i3sec.org” as I mistyped once above. ![]()
