So I massively overestimated how much disk space I would need for Qubes OS and would like to shrink the volume.
But I understand that shrinking a thin volume (LUKS) can be tricky. So I thought of a Backup-Format-Shrink-Reinstall-Restore Backup Solution.
I already backup all qubes weekly but in the documentation it says that in dom0 only files in ~\home will be backed up.
That’s bad because I was lazy with documentation when initially configuring my Qubes OS installation I am sure I modifies some global firewall settings, policies and usb settings with several
‚sudo nano something/something‘
which I now don’t remember throughly because I was just following random tutorials that just worked.
Everything works as it should now but I fear that a simple backup would not restore all these little changes I’ve made.
Is there any way to backup like EVERYTHING without copying the disk 1:1?
You can copy any file outside /home inside it with this command:
sudo cp -r /etc "$HOME"
In this case $HOME will be replaced by /home/<your_username>. You can then back up dom0. While restoring, you can go to the restored files and do:
sudo cp -r etc /etc
I took /etc as an example because I believe it’s the place where any configuration file should go. Before restoring them, it would be better to check the differences between a fresh Qubes OS configuration and the previous one, in order to document your changes.
You can probably look for any sudo nano command in the .bash_history file of dom0 to get an idea of those changes.
