Hello friends, I tried 3 days, but I need some help.
Using release 4.1 I had different service qubes connected each to a different USB controller. Now with 4.2 I am no more able to get it working.
The main problem is that with version 4.2 I cannot detach any usb controller from sys-usb to connect it with say sys-usb-clone-1, because to detach the USB controller from sys-usb I need to shutdown sys-usb, and if I shutdown it, then the mouse stops working. Without mouse how can I detach USB controllers?
I even tried to attach the USB controllers in the dvm template that I created to support sys-usb-clone-1 disposable, but it tells that:
“can’t attach PCI device to VM in pvh mode”
So, I find no way, I’m really confused. If you know how to solve it, please help your friend here.
And without sys-usb starting your mouse and keyboard will be connected to dom0 so you can freely clone your sys-usb and attach different USB controllers to each of them.
Hello, many thanks for your help,
I tried your suggestion, but now the mouse is always disconnected and without mouse I am only able to control dom0 terminal with the keyboard.
Did you remove the PCI devices that you’ve attached to sys-usb-clone-1 and sys-usb-clone-2 from sys-usb?
For mouse to work you need to configure the corresponding USB Input devices qrexec policy for the new sys-usb qube that has USB controller to which your USB keyboard and mouse are connected to. Open the Qubes Global Config → USB Devices and you can configure keyboard/mouse policy for new qubes there.
Many thanks again
I may imagine sys-usb, sys-usb-clone-1, sys-usb-clone-2 have all keyboard/mouse attached to. This may be the reason for the error. But now, you mention Qubes Global Config → USB Devices: is there a way to open it without a mouse?
Many many thanks @apparatus, your trick worked perfectly. I was able to regain control of the machine and found that yes sys-usb had only keyboard and mouse USB controller, but sys-clone-1 and sys-clone-2 kept not only their dedicated controller, but also mouse and keyboard controller. And I checked various times.
Wow this matter is now so delicate that a small error may get you unable to access your machine.
