Little embarassing, i7-12700KF does not have iGPU. My motherboard supports it though, so something to consider in the future.
Below is a sample of my Xorg log, which appears to load the Nouveau driver when I boot into 5.10.112. If I boot into 5.17.7-1, I can type in my disk encryption password and hit enter. I see the HDD LED go nuts and fans spin up a bit as if booting normally.
Assuming the system is working, is there a log that would capture the problem at this point and where would I find it after rebooting into 5.10.112?
Xorg.0.log:
[ 30.368]
X.Org X Server 1.20.11
X Protocol Version 11, Revision 0
[ 30.368] Build Operating System: 5.11.10-200.fc33.x86_64
[ 30.368] Current Operating System: Linux dom0 5.10.112-1.fc32.qubes.x86_64
[ 30.368] Kernel command line: placeholder root=/dev/mapper/qubes_dom0-root ro rd.luks.uuid=******** rd.lvm.lv=qubes_dom0/root rd.lvm.lv=qubes_dom0/swap plymouth.ignore-serial-consoles rd.driver.pre=btrfs rhgb quiet
[ 30.368] Build Date: 14 April 2021 12:00:00AM
[ 30.368] Build ID: xorg-x11-server 1.20.11-1.fc32
[ 30.368] Current version of pixman: 0.40.0
[ 30.368] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 30.368] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 30.368] (==) Log file: "/var/log/Xorg.0.log", Time: Sun May 29 12:02:02 2022
[ 30.393] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 30.393] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 30.406] (==) No Layout section. Using the first Screen section.
[ 30.406] (==) No screen section available. Using defaults.
[ 30.406] (**) |-->Screen "Default Screen Section" (0)
[ 30.406] (**) | |-->Monitor "<default monitor>"
[ 30.407] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 30.407] (==) Automatically adding devices
[ 30.407] (==) Automatically enabling devices
[ 30.407] (==) Automatically adding GPU devices
[ 30.407] (==) Automatically binding GPU devices
[ 30.407] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 30.407] (==) FontPath set to:
catalogue:/etc/X11/fontpath.d,
built-ins
[ 30.407] (==) ModulePath set to "/usr/lib64/xorg/modules"
[ 30.407] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 30.407] (II) Loader magic: 0x64f2787aae40
[ 30.407] (II) Module ABI versions:
[ 30.407] X.Org ANSI C Emulation: 0.4
[ 30.407] X.Org Video Driver: 24.1
[ 30.407] X.Org XInput driver : 24.1
[ 30.407] X.Org Server Extension : 10.0
[ 30.407] (++) using VT number 1
[ 30.407] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 30.409] (--) PCI:*(1@0:0:0) 10de:2489:1043:883c rev 161, Mem @ 0x52000000/16777216, 0x40000000/268435456, 0x50000000/33554432, I/O @ 0x00004000/128, BIOS @ 0x????????/131072
[ 30.410] (II) LoadModule: "glx"
[ 30.410] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[ 30.424] (II) Module glx: vendor="X.Org Foundation"
[ 30.424] compiled for 1.20.11, module version = 1.0.0
[ 30.424] ABI class: X.Org Server Extension, version 10.0
[ 30.606] (==) Matched nouveau as autoconfigured driver 0
[ 30.606] (==) Matched nv as autoconfigured driver 1
[ 30.606] (==) Matched modesetting as autoconfigured driver 2
[ 30.606] (==) Matched fbdev as autoconfigured driver 3
[ 30.606] (==) Matched vesa as autoconfigured driver 4
[ 30.606] (==) Assigned the driver to the xf86ConfigLayout
[ 30.606] (II) LoadModule: "nouveau"
[ 30.607] (II) Loading /usr/lib64/xorg/modules/drivers/nouveau_drv.so
[ 30.608] (II) Module nouveau: vendor="X.Org Foundation"
[ 30.608] compiled for 1.20.11, module version = 1.0.17
[ 30.608] Module class: X.Org Video Driver
[ 30.608] ABI class: X.Org Video Driver, version 24.1
[ 30.608] (II) LoadModule: "nv"
[ 30.608] (WW) Warning, couldn't open module nv
[ 30.608] (EE) Failed to load module "nv" (module does not exist, 0)
[ 30.608] (II) LoadModule: "modesetting"
[ 30.608] (II) Loading /usr/lib64/xorg/modules/drivers/modesetting_drv.so
[ 30.609] (II) Module modesetting: vendor="X.Org Foundation"
[ 30.609] compiled for 1.20.11, module version = 1.20.11
[ 30.609] Module class: X.Org Video Driver
[ 30.609] ABI class: X.Org Video Driver, version 24.1
[ 30.609] (II) LoadModule: "fbdev"
[ 30.609] (II) Loading /usr/lib64/xorg/modules/drivers/fbdev_drv.so
[ 30.610] (II) Module fbdev: vendor="X.Org Foundation"
[ 30.610] compiled for 1.20.6, module version = 0.5.0
[ 30.610] Module class: X.Org Video Driver
[ 30.610] ABI class: X.Org Video Driver, version 24.0
[ 30.610] (II) LoadModule: "vesa"
[ 30.610] (II) Loading /usr/lib64/xorg/modules/drivers/vesa_drv.so
[ 30.610] (II) Module vesa: vendor="X.Org Foundation"
[ 30.610] compiled for 1.20.6, module version = 2.4.0
[ 30.610] (II) NOUVEAU driver
[ 30.610] (II) NOUVEAU driver for NVIDIA chipset families :
[ 30.610] RIVA TNT (NV04)
[ 30.610] RIVA TNT2 (NV05)
[ 30.610] GeForce 256 (NV10)
[ 30.610] GeForce 2 (NV11, NV15)
[ 30.610] GeForce 4MX (NV17, NV18)
[ 30.610] GeForce 3 (NV20)
[ 30.610] GeForce 4Ti (NV25, NV28)
[ 30.610] GeForce FX (NV3x)
[ 30.610] GeForce 6 (NV4x)
[ 30.610] GeForce 7 (G7x)
[ 30.610] GeForce 8 (G8x)
[ 30.611] GeForce 9 (G9x)
[ 30.611] GeForce GTX 2xx/3xx (GT2xx)
[ 30.611] GeForce GTX 4xx/5xx (GFxxx)
[ 30.611] GeForce GTX 6xx/7xx (GKxxx)
[ 30.611] GeForce GTX 9xx (GMxxx)
[ 30.611] GeForce GTX 10xx (GPxxx)
[ 30.611] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 30.611] (II) FBDEV: driver for framebuffer: fbdev
[ 30.611] (II) VESA: driver for VESA chipsets: vesa
[ 30.786] (EE) [drm] Failed to open DRM device for pci:0000:01:00.0: -19
[ 30.786] (EE) open /dev/dri/card0: No such file or directory
[ 30.786] (WW) Falling back to old probe method for modesetting
[ 30.786] (II) Loading sub module "fbdevhw"
[ 30.786] (II) LoadModule: "fbdevhw"
[ 30.786] (II) Loading /usr/lib64/xorg/modules/libfbdevhw.so
[ 30.786] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 30.786] compiled for 1.20.11, module version = 0.0.2
[ 30.786] ABI class: X.Org Video Driver, version 24.1
[ 30.787] (EE) Unable to find a valid framebuffer device
[ 30.787] (WW) Falling back to old probe method for fbdev
[ 30.787] (II) Loading sub module "fbdevhw"
[ 30.787] (II) LoadModule: "fbdevhw"
[ 30.787] (II) Loading /usr/lib64/xorg/modules/libfbdevhw.so
[ 30.787] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 30.787] compiled for 1.20.11, module version = 0.0.2
[ 30.787] ABI class: X.Org Video Driver, version 24.1
[ 30.787] (II) FBDEV(2): using default device
[ 30.787] vesa: Refusing to run on UEFI
[ 30.787] (EE) Screen 0 deleted because of no matching config section.
[ 30.787] (II) UnloadModule: "modesetting"
[ 30.787] (II) UnloadModule: "fbdev"
[ 30.787] (II) UnloadSubModule: "fbdevhw"
[ 30.787] (II) FBDEV(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 30.787] (==) FBDEV(0): Depth 24, (==) framebuffer bpp 32
[ 30.787] (==) FBDEV(0): RGB weight 888
[ 30.787] (==) FBDEV(0): Default visual is TrueColor
[ 30.787] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0)
[ 30.787] (II) FBDEV(0): hardware: EFI VGA (video memory: 8100kB)
[ 30.787] (DB) xf86MergeOutputClassOptions unsupported bus type 0
[ 30.787] (II) FBDEV(0): checking modes against framebuffer device...
[ 30.787] (II) FBDEV(0): checking modes against monitor...
[ 30.787] (II) FBDEV(0): Virtual size is 1920x1080 (pitch 1920)
[ 30.787] (**) FBDEV(0): Built-in mode "current": 207.4 MHz, 85.3 kHz, 77.2 Hz
[ 30.787] (II) FBDEV(0): Modeline "current"x0.0 207.38 1920 1952 2192 2432 1080 1084 1088 1104 -hsync -vsync -csync (85.3 kHz b)
[ 30.787] (==) FBDEV(0): DPI set to (96, 96)
[ 30.787] (II) Loading sub module "fb"
[ 30.787] (II) LoadModule: "fb"
[ 30.787] (II) Loading /usr/lib64/xorg/modules/libfb.so
[ 30.788] (II) Module fb: vendor="X.Org Foundation"
[ 30.788] compiled for 1.20.11, module version = 1.0.0
[ 30.788] ABI class: X.Org ANSI C Emulation, version 0.4
[ 30.788] (**) FBDEV(0): using shadow framebuffer
[ 30.788] (II) Loading sub module "shadow"
[ 30.788] (II) LoadModule: "shadow"
[ 30.788] (II) Loading /usr/lib64/xorg/modules/libshadow.so
[ 30.789] (II) Module shadow: vendor="X.Org Foundation"
[ 30.789] compiled for 1.20.11, module version = 1.1.0
[ 30.789] ABI class: X.Org ANSI C Emulation, version 0.4
[ 30.789] (II) FBDEV(0): FBIOBLANK: Invalid argument (Screen blanking not supported by kernel - disabling)
[ 30.791] (==) FBDEV(0): Backing store enabled
[ 30.792] (==) FBDEV(0): DPMS enabled
[ 30.792] (II) Initializing extension Generic Event Extension
[ 30.793] (II) Initializing extension SHAPE
[ 30.793] (II) Initializing extension MIT-SHM
[ 30.793] (II) Initializing extension XInputExtension
[ 30.793] (II) Initializing extension XTEST
[ 30.793] (II) Initializing extension BIG-REQUESTS
[ 30.793] (II) Initializing extension SYNC
[ 30.794] (II) Initializing extension XKEYBOARD
[ 30.794] (II) Initializing extension XC-MISC
[ 30.794] (II) Initializing extension XFIXES
[ 30.794] (II) Initializing extension RENDER
[ 30.794] (II) Initializing extension RANDR
[ 30.794] (II) Initializing extension COMPOSITE
[ 30.794] (II) Initializing extension DAMAGE
[ 30.794] (II) Initializing extension MIT-SCREEN-SAVER
[ 30.794] (II) Initializing extension DOUBLE-BUFFER
[ 30.794] (II) Initializing extension RECORD
[ 30.795] (II) Initializing extension DPMS
[ 30.795] (II) Initializing extension Present
[ 30.795] (II) Initializing extension DRI3
[ 30.795] (II) Initializing extension X-Resource
[ 30.795] (II) Initializing extension XVideo
[ 30.795] (II) Initializing extension XVideo-MotionCompensation
[ 30.795] (II) Initializing extension SELinux
[ 30.795] (II) SELinux: Disabled on system
[ 30.795] (II) Initializing extension GLX
[ 30.795] (II) AIGLX: Screen 0 is not DRI2 capable
[ 30.985] (II) IGLX: Loaded and initialized swrast
[ 30.985] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 30.985] (II) Initializing extension XFree86-VidModeExtension
[ 30.986] (II) Initializing extension XFree86-DGA
[ 30.986] (II) Initializing extension XFree86-DRI
[ 30.986] (II) Initializing extension DRI2
[skip a few]
[ 31.090] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event14)
[ 31.090] (II) No input driver specified, ignoring this device.
[ 31.090] (II) This device may have been added with another device file.
[ 31.090] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event15)
[ 31.091] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event16)
[ 31.091] (II) No input driver specified, ignoring this device.
[ 31.091] (II) This device may have been added with another device file.
[ 31.091] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event17)
[ 31.091] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event18)
[ 31.092] (II) No input driver specified, ignoring this device.
[ 31.092] (II) This device may have been added with another device file.
[ 31.092] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event19)
[ 31.092] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=12 (/dev/input/event20)
