Yes I did search.
I created a USB qube, gave it my PCIE controllers and now well, my system freezes upon startup when it fails to start that qube after I decrypt the disk. Can I delete it somehow by going into a live distro? Thanks
Yes I did search.
Follow these steps to disable qubes autostart and then remove the PCI device you added to sys-usb:
Well, thanks for that, it worked. Now my issue is that the panel disappeared and if I don’t mirror my 2 monitors, 1 of them shuts off
Edit: Resolved panel issue
Second Edit: resolved everything by switching some cable.
