Framework Laptop + v4.3?
Does anyone try to test all Framework Laptops mainboard works well with v4.3?
I am using Qubes 4.3 in a Framework 13 with an AMD 7040 mainboard, and in a Framework 12 with the i5-1334U mainboard.
Everything seems to work well (with some minor annoyances).
Battery life is pretty bad in the 13, and half-decent in the 12.
Thank you
I am running 4.3 on a Framework 13 with an Intel Ultra 7 165. Seems to work fine
I mean as all the features working 100% well? Without modified?
The FW13 13th gen intel boards still have S3 support, so everything works fine with that one. Well, ignoring the fact that all the Framework laptop’s I’ve seen have horrible battery drain in sleep mode.
