Framework Laptop 13 Pro is stable?
Now with Framework Laptop 13 Pro: Core Ultra 5 325, Core Ultra X7 358H, & Core Ultra X9 388H? Now with CAMM RAM? Whose will try to tested as stable uses?
Hi, i have now the ā€œUltra X7 358Hā€ variant. So far, I haven’t managed to get Qubes running in a usable state. Installation using the 4.3.1 image was possible in text mode (via VNC) with kernel-latest. However, the system only boots with `nomodeset`. The graphics chip is not yet supported by the available drivers, and sys-usb and sys-net also appear to be having issues, though they do start . Right now, I only have console access without network in Qubes ;- (. Access to sys-usb and sys-net via ā€œxl consoleā€ fails. If anyone has tips on getting the system up and running, that would be great.
Here is the output of lspci of this machine:
00:00.0 Host bridge: Intel Corporation Core Ultra Processors (Series 3) PTL-H12Xe (rev 04)
00:02.0 VGA compatible controller: Intel Corporation Panther Lake [Arc B390] (rev 04)
00:04.0 Signal processing controller: Intel Corporation Core Ultra Processors (Series 3) DTT (rev 04)
00:06.0 PCI bridge: Intel Corporation Core Ultra Processors (Series 3) PCIe Root Port #9 (rev 01)
00:07.0 PCI bridge: Intel Corporation Core Ultra Processors (Series 3) USB Type-C Subsystem PCIe Root Port #21 (rev 01)
00:07.1 PCI bridge: Intel Corporation Core Ultra Processors (Series 3) USB Type-C Subsystem PCIe Root Port #22 (rev 01)
00:07.2 PCI bridge: Intel Corporation Core Ultra Processors (Series 3) USB Type-C Subsystem PCIe Root Port #23 (rev 01)
00:07.3 PCI bridge: Intel Corporation Core Ultra Processors (Series 3) USB Type-C Subsystem PCIe Root Port #24 (rev 01)
00:0a.0 Signal processing controller: Intel Corporation Core Ultra Processors (Series 3) Crashlog and Telemetry (rev 04)
00:0b.0 Processing accelerators: Intel Corporation Core Ultra Processors (Series 3) NPU (rev 04)
00:0d.0 USB controller: Intel Corporation Core Ultra Processors (Series 3) Type-C Subsystem xHCI (rev 01)
00:0d.2 USB controller: Intel Corporation Core Ultra Processors (Series 3) Thunderbolt DMA0 (rev 01)
00:0d.3 USB controller: Intel Corporation Core Ultra Processors (Series 3) Thunderbolt DMA1 (rev 01)
00:13.0 Communication controller: Intel Corporation Core Ultra Processors (Series 3) CSME HECI #1 (rev 01)
00:14.0 USB controller: Intel Corporation Core Ultra Processors (Series 3) Standalone xHCI Controller (rev 01)
00:14.2 RAM memory: Intel Corporation Core Ultra Processors (Series 3) Shared SRAM (rev 01)
00:14.3 Network controller: Intel Corporation Core Ultra Processors (Series 3) CNVi Wi-Fi (rev 01)
00:14.7 Bluetooth: Intel Corporation Core Ultra Processors (Series 3) CNVi Bluetooth (rev 01)
00:15.0 Serial bus controller: Intel Corporation Core Ultra Processors (Series 3) I2C #0 (rev 01)
00:15.1 Serial bus controller: Intel Corporation Core Ultra Processors (Series 3) I2C #1 (rev 01)
00:15.2 Serial bus controller: Intel Corporation Core Ultra Processors (Series 3) I2C #2 (rev 01)
00:15.3 Serial bus controller: Intel Corporation Core Ultra Processors (Series 3) I2C #3 (rev 01)
00:16.0 Communication controller: Intel Corporation Core Ultra Processors (Series 3) CSME HECI #1 (CSE) (rev 01)
00:18.0 Communication controller: Intel Corporation Core Ultra Processors (Series 3) CSME HECI #1 (rev 01)
00:19.0 Serial bus controller: Intel Corporation Core Ultra Processors (Series 3) I2C #4 (rev 01)
00:19.1 Serial bus controller: Intel Corporation Core Ultra Processors (Series 3) I2C #5 (rev 01)
00:1f.0 ISA bridge: Intel Corporation Device e402 (rev 01)
00:1f.3 Audio device: Intel Corporation Core Ultra Processors (Series 3) HD Audio (rev 01)
00:1f.4 SMBus: Intel Corporation Core Ultra Processors (Series 3) SMBus (rev 01)
00:1f.5 Serial bus controller: Intel Corporation Core Ultra Processors (Series 3) SPI (flash) Controller (rev 01)
01:00.0 Non-Volatile memory controller: Sandisk Corp SanDisk Extreme Pro / WD Black SN750 / PC SN730 / Red SN700 NVMe SSD
I hope we can get the Framework 13 Pro’s up and running quickly. I think it’s a great device.
I’ve finally gotten it to work.
After installing via VNC, you should edit the grub.conf file to use the xe driver instead of the i915 driver.
This will also make the initial setup dialog work.
I had to configure X to use ā€œmodesettingā€ and set the ā€œAccelMethodā€ to ā€˜sna’ or ā€œnone.ā€
To get Bluetooth working, I installed the ā€œlinux-firmwareā€ package from the testing repository; this was also necessary for ā€œsuspend2ramā€ to work.
I hope this helps you.
I’ll post a compatibility report in a few days.
Have fun with it.
Super​:+1:. Now that i can calm down with using with LPCAMM RAM.
Hi, in your original message, you mentioned that you had issues with sys-usb and sys-net. Were you able to get those working? I am planning to order Framework 13 Pro and wondering if 358H is stable to run Qubes.
You mean Core Ultra X7 358H?
Yes
Hi, yes i’m very happy with the framework 13 pro (X7 358H). With the mentioned steps before it is working stable for me. Suspend to ram is working. Battery life is very good.
Super​:+1::saluting_face::trophy::four_leaf_clover::white_check_mark::100:
Hi
I don’t understand how do I install via VNC? I don’t have this option when booting the installer.
Also, how do I edit grub.conf file in order to use the xe driver? Can you show please?
And the X thing, where do I put these? Also in grub.conf? What is the difference between ā€˜sna’ and ā€˜none’?
Should I install ā€˜linux-firmware’ for bluetooth to work in dom0 or in templates or in sys-usb?
how do I do that? Thx
However you put it, framework 13 even after this is not going to be fully stable because the chip lineup is not fully supported in the kernel yet, it will need some more time.
A good way to check how fsr support has come, is to run fedora and see how that pans out. Usually a couple months after that support exapnds over to qubes
Nevermind, I installed it using recommendations from this issue – Framework 13 pro Intel freezes after drive decryption Ā· Issue #11179 Ā· QubesOS/qubes-issues Ā· GitHub
It was easy.
Hey,
I was able to install Qubes and I am loving it so far
However there is an issue: If I don’t touch keyboard for like 2-3 minutes, the display freezes and it doesn’t reposnd to anything on keyboard. The only thing I can do is press the power button for 10 seconds to force shutdown.
But audio works fine: I let the video play, and when everything froze, audio continued to work normally
Please help me diagnose/fix the issue
