I am planning to buy a Framework Laptop 13 Pro and install Qubes on it, and I have a few questions regarding this:
I am choosing a CPU, I am mostly interested in ‘Intel Ultra X7 358H’ and ‘AMD Ryzen AI 9 HX 370’. According to the benchmarks, the Ryzen AI is going to perform better, and I personally prefer AMD over Intel, but as far as I know, Intel processors are generally more recommended for Qubes, due to better support and faster security updates. What should I take into account when making this choice?
I couldn’t find a lot of information on this, but if I go with Intel, I would like to utilize SR-IOV to “cut” my iGPU into smaller ones, and assign these virtual GPUs to VMs. As far as my research goes, from this page the SR-IOV is unsupported on ‘Panther Lake’ family, but is there any chance it will be in the future?
Is 32GB of RAM enough for comfortable multitasking on Qubes? (eg. Browser opened, text editor opened, music player opened, messenger opened, something else is opened)
This should eventually be fixed, and also you’ll wait quite some time for that Framework laptop to arrive (looks like buying now will get you one in September), but right now this one specifically may be problematic.
As for SR-IOV, oh, they retracted the support from PTL too Something similar happened to LNL before - at last minute the commit enabling support there was dropped. But for PTL, the support seems to be included in Linux (Making sure you're not a bot!) since quite some time. But, here also I didn’t got much success in practice (on LNL, I don’t have PTL, yet).
I have seen people reporting successes with i915 + SR-IOV patches (there is a DKMS module that retrofits old Intel patches, before they stopped working on official SR-IOV support for i915 driver). But with this approach, you’ll face another issue - i915 driver doesn’t support LNL or newer anymore…
So, the situation on the Intel GPU side doesn’t look great right now, but there is hope
As for AMD, yes, they are usually slower at delivering microcode updates for desktop/mobile CPUs. And also, I don’t think they even plan supporting virtualization with integrated GPU (or desktop models either for that matter). So, from the feature/security point of view, Intel seems like a better choice. But, right now, with the switch from i915 driver to xe driver, there seems to be a couple of reliability issues.
As for memory amount, I’d say yes. My daily driver has 32GB and it’s perfectly fine.
That’s odd that Panther Lake got marked as SR-IOV unsupported. Maybe they let the people who were maintaining it go, so they didn’t want to call it out as supported? It’s also odd that Arrow Lake is marked as supported, since it’s pretty much Meteor Lake which isn’t supported. Arrow Lake uses the same drivers as Meteor Lake in Linux.
For the Linux kernel, SRIOV support is marked in xe_pci.c as “.has_sriov = true”. It’s enabled in the latest kernel for:
Tiger Lake (11th gen)
Alder Lake (12th gen)
Raptor Lake (13th/14th gen - Uses the Alder Lake drivers in Linux)
Panther Lake (Ultra Series 3)
Arctic Sound-M (Data Center GPU)
Battle Mage (While it’s only marked as BMG, I believe this is only supported on the Pro models)
Meteor Lake and Arrow Lake have unofficial support via some third party patches. Lunar Lake doesn’t.
