I don’t know if I have dust in my eyes, but where is it possible to find easy help about this forum syntax ?
I had a hard time finding it :
- I didn’t know that this forum was using “discourse”
- but even then, the discourse website has NO help/documentation link ! o_O
For anyone looking for the same thing, I found this : An Unofficial Discourse User Reference Guide
From previous link I learnt that the syntax is called markdown
(or commonmark
?), and you can read a quick guide here: Markdown Reference
TL;DR, forum help :
- The 1st link is for a detailed guide with examples
- The 2nd link is more of a quick guide, but at the bottom you can find links like “10 minute interactive tutorial”, or “play with the reference CommonMark implementation”
I think there should be a sticky somewhere, looking for “forum syntax” provides 0 results ! Well, maybe one after I post ? ^^
