Hi.
I installed Florence keyboard on dom 0. But i have some questions/ problems.
Once I open the terminal or a text file. It does not open automatically. I have to go to the menu to start the virtual keyboard. Is there a way to set it up to start when there is not a usb keyboard?
And about the first screen where you have to type your password. I can not open the virtual keyboard to use it instead of the usb one.is there a set up to do this?
Regards
Hi.
About your first question, i have to say that i am not sure. When I installed it, i am pretty sure that it worked in dom0 but when i tried again to check your question, i found that i can start it but it does not work. It does not work in any terminal plus in a writing file.
About the second one. It does not work in both steps. I thought that it would start in both of them. But I tried it but using the touch screen did not work and it did not work either when i pressed any button of the device.
Hi.
I installed florence again plus kvkbd keyboard. And they work pretty well on the qubes terminals as well as it works on the libre office in different qubes even in dom0.
But i can not make it work on the decryption phrase screen nor the pasword screen . Is there a script which i should make to get that?
Regards
this will not be possible as a very minimal system is running to allow you to type, you can’t run much programs and not even mentioning no GUI programs at this stage of the boot
