Today, the Qubes-OS team published the first fedora-44 templates for testing .
So please, test theses templates and report issues in the main fedora-44 issue.
How to test ?
In dom0, launch qvm-template-gui. If not already done, add the qubes-template-itl-testing repository and refresh. Then install the wanted template from the available list:
Then create a new fedora-44 qube-app, and test it.
How to report problem ?
Add a new comment in the below #10703 issue, with a description of the problem and the steps to reproduce it.
opened 12:51PM - 19 Feb 26 UTC
C: Fedora
P: default
Fedora 44 (https://fedorapeople.org/groups/schedule/f-44/f-44-key-tasks.html) is… planned for late April.
Tasks:
- [x] build all packages
- [x] update rpmfusion to final released version
- [x] build the template
- [ ] document
- [ ] upload to testing repo
- [ ] migrate to stable repo
- [ ] announce
If any issue affects Fedora 44 specifically (build failures, things that worked fine before etc.), please add reference to this issue too.
Let’s play !
user@dom0:~$ qvm-ls |grep fedora.44
fedora-44-xfce Halted TemplateVM black - -
test-fedora44 Running AppVM red fedora-44-xfce sys-firewall
Note that starting with this release, the Gnome template will use the -gnome suffix .
If you installed the qubes-template-fedora-44-xfce-4.3.0-202604280254 , I suggest that you install the new qubes-template-fedora-44-xfce-4.3.0-202605021558 , with qvm-template(-gui).
In fact, I did a simple template update (qubes-update-gui) and I didn’t get the rpmfusion , security-testing repo and update-notification fixes. So it’s a good idea to install the new template.
Now the fedora-44 template is my a daily driver for a basic qube-app.
